Old member
Bought the seats a month ago at the local LQ yard for $60.00. Got the electronics working on both of them except for the drivers side heater. I have ordered new covers for them both and plan on putting aftermarket heaters in them so I will have both bottom and backs heated instead of just bottoms.
I bought the console off a local member here and will have it refurbed to new again I hope and will install them all into the 71 when done. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Old member
Here is the bad of it. The console I hope can be fixed with some minor work. These are the only problems I can find wrong with it. I'll replace the cup holders with the stainless ones if I can find them with new trim also I hope.
The inside frame is cracked up front and there is a small hole on the side right at the trim. Shouldn't take much to fix I hope. ![]()
Re: Seats and console
Cant wait to see this Andy....I too like the older console with newer seats......I might install mine with 2000 trans am seats without the headrest.......the main thing wrong with my truck this year's Power Tour was the bench seat became uncomfortable and no cup holder.....plus a console would me clean up the cab quickly with a place to tuck stuff away..........
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
Old member
I like my 89 Chevy bench seat but just ready for a change. I have cup holders also to in the S-10 shifter I installed.
Old member
Can you not buy the slip out cup holder for the ashtray mod?
How wide are the classic consoles?
-Jason USN Retired |
Old member
Here is what I'm looking for. Just to give a idea. Once I have the heaters and new covers installed I will start placing everything in the truck.
Going to work on the speaker boxes also and how everything is mounted. ![]()
Rhat set-up looks so nice and clean. Wonder if the headrest will work?
#10 | |
Old member
![]() Quote:
Yes I can/could and might do that if I dont get around to interior redo before 2015 Power Tour(where ever we may be going).....but that option may not make my lower back and butt happy while long hauling in 2015
#12 | |
Old member
![]() Quote:
![]() ![]() ![]() ![]() Understand! ![]()
#13 |
Old member
Drivers side is installed and wired. Seats move as they should and heaters are working. Got to drive it the rest of the week and see how everything feels and wait for my next night off which is Sunday before I start on the passenger side. I'll have to drill holes for it. The drivers side went good the brackets mounted right back in the same holes as the old seat. Seat belts everything was a easy swap.
I had plan to have the heaters turn off with the seat belt if you unbuckled it and left the switch on but the little wire pig tails in the buckle work in reverse for a buzzer I guess. They will cut off when I turn the truck off but would like to have a safety cutoff if someone forgets. Anybody know a way to do this? ![]()
#14 |
Those will look sweet! What did those seats come out of? I have some bucket seats but I'm old and want an arm rest.
Also ( off subject) but what kind of tilt column do you have? The ones I've seen don't ever look like they tilt "up" as high as yours.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
#15 | |
Old member
![]() Quote:
Seats are out of a 99 Tahoe. I bought the new covers and new heaters for them. My old buns will be warm this winter! ![]() ![]()
#16 |
Old member
Seats are both in wired and ready to ride. I worked all night on them. I have the seat belts working like I want and they cut the heaters off if the switch is left on and you unbuckle the belt.
This way I don't have to worry about weather are not it's burning the heater element up for no reason! Oh yea I went back out and fixed the seat cover around the controller on the passenger side. It looks a lot better. I have the console sitting on the kitchen table drying after I epoxed the crack back together. I will body fill and sand the other places sometime polish up the S/S trim piece and buy the cup holders. Mount my 2 amps inside the thing once it's ready to install. ![]() https://www.youtube.com/watch?v=WKgJ1P_h69Q
#17 |
Now Im waiting on to see how counsel turns out just as long as it doesnt interfere with your "bangshift"-ing activities Andy after install.........lol................
#18 |
So very nice
#19 | |
Old member
![]() Quote:
#20 |
![]() Join Date: Oct 2001
Im digging the gray,, looks modern....
Things happen for a reason! |
#21 |
Old member
![]() Thanks, I think it looks good too. I'm picking up the new red carpet for it Friday. ![]()
#22 |
Those seats look great....I'll be checkin' local craigslist for 99 Tahoe seats also !
#23 |
Looks good!
Where did you order the covers from?
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#24 |
Old member
Thanks guy's I think they came out great for the price compared to new covers with heaters.
Here is the link. http://www.autoanything.com/seat-cov...A4353A0A0.aspx I have all the wiring ran through the seat wiring harness plug. Everything is unplug with one connector and the seat is ready to come out. ![]()
#25 | |
