11-02-2014, 03:09 PM | #1 |
To undercoat or paint?
Curious as to what you guys are doing to the bottom of your cabs.
Are you just painting them or are you using some kind of undercoating? I've read where the undercoating can actually make corrosion a bigger problem than just painting. I'm going to use a sound deadening mat on the inside so that's not a concern. I've already put epoxy primer on it. Thanks for any reply's. Kim |
11-02-2014, 03:32 PM | #2 |
Re: To undercoat or paint?
I would not undercoat. I have found cars with undercoating have more rust then those without. When the undercoating seperates from the metal it's a place to trap dirt and water. If you can guaranty the undercoating will never separate then it would be good. Paint looks better also. Amatuer applied undercoating is usually done by those trying to hide problems.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
11-02-2014, 03:48 PM | #3 |
I am having mine rhino coated.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
11-02-2014, 04:53 PM | #4 |
I found very very little rust under the under coating I removed from the bottom of my cab. Most of the Stuff was hard as concrete. The rust was actually where their was no under coating, not under the undercoating.
After removing it all, I used rustoleum rusty metal primer and rustoleum gloss black paint. Applied both with brush, and let it dry for a week between primer and paint. (used the same on the frame) Then used I think it was 8 cans of spray undercoating. I think it'll be good for another 57 years. |
11-02-2014, 05:45 PM | #5 |
I always paint mine and then undercoat them.
GOD BLESS AMERICA! |
11-02-2014, 06:28 PM | #6 |
Moderator
"Undercoating" like the popular dealer add-on in the 70's and 80's is totally different than modern polyurethane/polyurea coatings. I just had all my rust replaced and bedliner sprayed top and bottom of the floor and inside the firewall. Very impressed with how it turned out and I can't see rust being a problem for a long time now.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-02-2014, 07:26 PM | #7 |
i too did rhino liner under the cab and behind the stock fuel tank
also sprayed it under all my fenders and inner fenders this was more for rock protection popping up but it also firms up the sheet metal you can see the line of the bed liner up on the firewall
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-02-2014, 07:57 PM | #8 |
Kim, I didn't use any undercoating on mine. I did paint it with POR15, then immediately mist on some primer and let in dry. This makes it possible to paint over POR15. Then I painted the same as rest of cab. 10 yrs and 22,000 miles later still looks good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-02-2014, 08:32 PM | #9 |
Certified Car Nut
Epoxy primer for rust protection and then I sprayed raptor liner. I don't see how liner could cause rust used as just a top coat. Also remember with the way we are tearing these trucks apart and redoing them most of us will not be around by them time they rust again. And for us weekend cruiser guys who will baby are trucks I do see how the could rust. These trucks were driven and treated harshly way before we got them and I believe we really over think a lot of this stuff. They did not have the paint technology we have today nor did they baby them back then.
11-02-2014, 09:23 PM | #10 |
Thanks for the info guys.
This gives me some things to think about. I've been looking at the Raptor liner as the kits without the gun seem to be pretty inexpensive and I have access to a gun. Thanks again. Kim |
11-02-2014, 11:17 PM | #11 |
my truck i just bought about a month ago (60 c-10) has what im guessing is old undercoating under the cab and on the inside of the cab floor... it feels like a solid truck, but im afraid to find out what is between the layers.
i think if i had my cab off, and was at the paint stage. i would probably rhino line the underneath and behind the tank...but thats about it |
11-02-2014, 11:19 PM | #12 |
I am very happy how the steps are protected on my daily driver.
I had the undersides of the fenders done to protect them from whatever the tires fling up at them.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
11-03-2014, 06:07 AM | #13 |
I blast,clean,por-15 and then use the Raptor on anything underneath also inside any parts like inner/outer rockers that get welded together. The Raptor should be enough by itself and the por gets stronger with moisture so between the two I don't forsee my grandchildren having to fix anything. Plus I figure if any water does get into a closed cavity it will be like it's sitting in the bed of a pickup.
Nice EASY project, no problem....until I get home why is that? My build: http://67-72chevytrucks.com/vboard/s...d.php?t=595078 |
11-03-2014, 09:15 AM | #14 |
Thanks guys.
I do like the way the Raptor looks on Bam's truck so I'll more than likely go that route. Kim |
11-03-2014, 10:40 AM | #15 |
Just black SPI epoxy primer on mine.
Same for the underside of the hood and the inner fenders. I did undercoat the fenders and the wheel side of the inner fenders though. Put on the epoxy primer first then did it. |
11-03-2014, 02:11 PM | #16 |
fyi... i did epoxy primer before sending out for rhino liner
i think that is an important step
11-03-2014, 02:27 PM | #17 | |
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
11-03-2014, 05:14 PM | #18 |
I have it all sprayed with SPI grey epoxy right now.
I know I'm definitely going to under coat the inner fenders for protection from rocks but not sure about the cab bottom yet. Kim |
11-04-2014, 10:16 AM | #19 | |
A wise man speaketh:
11-04-2014, 01:09 PM | #20 |
i would under coat, but that is me ....
dont want to hear excuses, i want to hear solution(s) |
11-04-2014, 06:46 PM | #21 |
11-04-2014, 09:42 PM | #22 |
Just bed liner goop.
Probably 1500 short-run miles of wear and tear and it is working super good.
