Roto Reuter thats the name...
![]() Join Date: Feb 2010
New to lowered suspension… What to use?
I'm looking to do a frame off on my '71 SWB and want to lower it. I'm thinking of around a 4/6 drop, probably 20" wheels, but want to know the right way to do it. I am thinking about using a new drop member with rack & pinion and coil overs in the front. For the rear I'm thinking about a 4-link with 9" rear end and coil overs. don't know if I need a C-notch or not? From what I've read I don't think so, but if the whole truck is removed from the frame, probably just as easy to do it. I appreciate any input. I'm definitely going to learn on this one.
This may sound crazy, but if I'm planning to go through all of this would I be better off with complete new chassis? By the time I add all of this to my existing frame it will add quite a bit.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Re: New to lowered suspension… What to use?
I just did mine with the ride tech 4 link on the rear and drop spindles with coil overs on the front. The kit comes with c notches for the rear. You can get a great riding and handling truck with this set up. The drop cross member would most likely only be needed if you were putting air ride on it and wanted the ride height very low.
Don't sweat the petty things and don't pet the sweaty things. |
![]() Join Date: Jan 2011
For as little drop as you are looking to do I would use drop spindles and 2" springs in the front and a set of 4" springs and 2" blocks in the back with a bolt in C notch. Will sit nice and not break the bank.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I'm thinking of going with rack & pinion steering too, so wouldn't it be best to just go with a front drop member? Maybe it's not necessary. I'm just trying to learn.
Our complete kit drops the truck exactly where you want it. This suspension setup was designed using a "clean slate" approach and on streettires can maintian .98 lateral g's on the skid pad. Combined with our tuned shocks, it will drive and handle as good as a newer Vette! If you have any questions, feel free to ask.
Here's a little video of a couple of our R&D trucks at work. http://www.youtube.com/watch?v=Hgef-d3MA2o#t=21 |
GOD BLESS AMERICA! |
Really depends on what you want in the end. If you want a nice lowerd daily driver that drives well than the method I posted can fit that bill quite well. If you are looking for an auto cross setup that will handle like a sports car than there are systems for that. So the next question is what is your goal for this truck in the end of the project and what is your budget for the suspension? 2K or 10K? as you can do it for either and have a good driving truck.
Jimmy
#8 | |
#9 | |
No limit has a nice setup and here is a thread on another option. http://67-72chevytrucks.com/vboard/s...d.php?t=589967
Jimmy
