Patina clean up
How do you guys clean up your patina on your trucks? I love they it looks but i dont want it to be grungy just old and worn if the makes any sense.
Re: Patina clean up
A lot of people use CLR and a scotch brite pad. Then flat clear coat.
66 shorty ![]() |
Re: Patina clean up
I think there's a post with a lot of pics and details about this, i will check to see if i saved it.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Patina clean up
Look at this thread,...
http://67-72chevytrucks.com/vboard/s....php?p=6029956
![]() Join Date: Aug 2010
Re: Patina clean up
Re: Patina clean up
Re: Patina clean up
Scotchbrite is way too rough!! Use 0000 steel wool like oem4me posted. CLR works great to remove rust stains.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: Patina clean up
I used a bunch of 3000 grit Trizact pads then followed that with McGuire's show car glaze to moisturize the paint then waxed. It's best to let the glaze sit as it tends to brighten the paint color. I was striving to minimize paint removal on my truck. I read a thread on autogeek.net I think it was that headed me in that direction. the attached pictures give an idea of how it removed the chalky oxidation and it actually has a bit of shine now. The last picture is an older pic taken in 2010 but it will show you what I did.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
Re: Patina clean up
Thats what Im looking for! Thanks guys!
Re: Patina clean up
Make sure that you post some before and after pictures. endlessearth put me onto this same CLR route some months ago. I just have not gotten that far yet as there are other pressing things on my plate. I also have some cracking of the paint that I am not sure how to address.
