Old 11-03-2014, 12:17 AM   #1
jcd9730
jcd9730's Avatar
What is this?
Can anyone tell me what this is? It looks like it came apart and it's pretty loose. The circle part at the top below that coupler is freely spinning. Also, how do I take that off? I'm hoping that doesn't involve taking the whole column out or the steering box....
Josh
72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs...
jcd9730 is offline   Reply With Quote
Old 11-03-2014, 12:38 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: What is this?
Looks like you are missing the spring and your lower steering shaft bearing fell out. Read through this thread and see if it helps....
http://67-72chevytrucks.com/vboard/s...d.php?t=471499
LockDoc
Leon
Old 11-03-2014, 12:51 AM   #3
jcd9730
jcd9730's Avatar
Re: What is this?
Ohhh okay. Is it bad if I drive it like this for a bit until I have time to fix it?
Josh
Old 11-03-2014, 12:58 AM   #4
LockDoc
LockDoc's Avatar
Re: What is this?
I can't honestly answer that question, I don't know.
LockDoc
Leon
Old 11-03-2014, 02:14 PM   #5
Fitz
Re: What is this?
I would not drive it until that is returned to the original condition as I do not know what other bad things could be hiding inside that column.
It's OK to take a chance with it as long as you are the only one that pays if that steering linkage fails when you're driving. The problem is, while you may not have a passenger there are others on the road with you and if you lose steering you WILL hit something.
Fitz is offline   Reply With Quote
Old 11-03-2014, 02:43 PM   #6
Old Truck Man
Old Truck Man's Avatar
Re: What is this?
The bottom collum bearing has failed. Ive seen steering shafts worn pretty bad from being driven with that bearing gone. And it also sometime has to do with the rubber cab mounts. sometimes the cab settles and puts the shaft in a bind andthe pressure is simply too much for that little bearing to handle.I would fix it pronto.
Old Truck Man is offline   Reply With Quote
Old 11-04-2014, 09:51 PM   #7
no1udknow
no1udknow's Avatar
Re: What is this?
+1
looks like bottom column bearing. That thing free spinning is the bearing race. I wouldn't drive it. My cousin tried to drive his lifted 75 c10 like that and tore the leather damper thing where the shaft couples to the steering box and put it in a ditch. Steering components are no joke.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 11-04-2014, 02:15 PM   #8
jcd9730
jcd9730's Avatar
Re: What is this?
Do y'all know a part number or link or something? I'm still not totally sure what to look for
Josh
Old 11-04-2014, 03:21 PM   #9
john
member #16
john's Avatar
Re: What is this?
Wes at classicheartbeat has lower column bearings. Might not hurt to check the upper also.
http://www.classicheartbeat.com/steering_column.htm
john is offline   Reply With Quote
Old 11-04-2014, 09:27 PM   #10
jcd9730
jcd9730's Avatar
Re: What is this?
Awesome, thanks for the help. Ordered both, just in case.
Josh
Old 11-04-2014, 10:27 PM   #11
LockDoc
LockDoc's Avatar
Re: What is this?
Did you order the spring too? You will still need that.
LockDoc
Leon
Old 11-04-2014, 11:26 PM   #12
jcd9730
jcd9730's Avatar
Re: What is this?
Lower bearing came with it!
Josh
Old 11-04-2014, 11:49 PM   #13
LockDoc
LockDoc's Avatar
Re: What is this?
Sounds good!
LockDoc
Leon
