11-03-2014, 09:47 AM | #1 |
Power window motors
Are the front and rear window motors the same? I need a motor for the rear and can't seem to find any info on them...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
11-03-2014, 09:53 AM | #2 |
Re: Power window motors
I think they are the same... Just wanted to make sure
11-03-2014, 12:12 PM | #3 |
I believe they are the same
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
11-03-2014, 04:04 PM | #4 |
I think so... I went a head and ordered one so we will see... Lol thanks for the reply!
11-04-2014, 12:01 AM | #5 |
I bought four of the same part number for my suburban, drilled the old adapters off and used small bolts to attach to the new motors. Works a lot better now but would like to do the relay wiring mod someday.
11-04-2014, 06:00 AM | #6 |
Yea I'm doing the relay mod as well, and one piece side glass
11-04-2014, 10:47 AM | #7 |
I considered the relay mod but then discovered that a new Delco motor solved the slow window problem on my 83 C20. I had previously installed Delco motors but found out that they had two different part numbers. When I bought the second replacement motor it was much faster - I believe it was the one that came without the mounting bracket attached, and it was the less expensive of the two models. I will eventually change the other motor with the cheaper one. It may just be that I got poor quality motors the first time, but I think that second motor was a slightly different style. So, I think I would look for those low priced Delco motors. As I recall, the Delco motors were actually cheaper at the OEM vendors than aftermarket motors. I would try the usual suspects:
www.oewarehouse.com www.oehq.com www.autopartstomorrow.com www.rockauto.com www.gmpartsdirect.com Another seller is Dave's Auto Parts, which sometimes has parts that the other vendors do not have. I have used all of these vendors with success, and some like the first two have free shipping or low cost shipping. |
11-04-2014, 10:54 AM | #8 |
Cool thanks for the info!
