Old 11-03-2014, 11:17 AM   #1
Dawson67
Door adjustments
How do I adjust the doors so the sit flush. They look even and flush all around except the back Name:  image.jpg
Dawson67 is offline   Reply With Quote
Old 11-03-2014, 11:24 AM   #2
Steve Cole
Re: Door adjustments
If they are not pulling in far enough in the rear, you can move the latch catch on the cab in a little so the door has to close further to engage. Move in small increments though.
Steve Cole is offline   Reply With Quote
Old 11-03-2014, 11:27 AM   #3
Dawson67
Ok I'll try that thanks
Old 11-03-2014, 08:07 PM   #4
hugger6933
This may sound strange but if it is sticking out the striker may need to come out a small bit. Keep that in mind if you are at the end of your rope and are looking for the knot to grasp on to. This is because the latch if you feel it when you press the door closed it has two positions,well after the second is a half position almost that will feel like it is gonna go in and latch but it kicks back. It is kicking back into the second position[that is the normally all the way closed position] I am trying not to word this where it sounds to silly don't know if it is working. OK, more things may be helpful,the bolts on the hinges on the trucks side of the hinge move the door forward and backward in the "pocket"[pocket:body mans term for the door opening]. The bolt on the hinge that are on the door side move the door up and down and tilt and "twist" in the pocket.
hugger6933 is offline   Reply With Quote
