Old 11-03-2014, 01:32 PM   #1
GMC Guy
GMC Guy's Avatar
let's talk, Posi.
trying to decide which carrier i want to run in my 12 bolt. Not looking for a locker, just a nice, quiet, smooth, reliable, strong, limited slip unit that will allow for enjoyable street driving, but then light up both 295/50's when i want.
also, switching to 3.73's, which company would you recommend for gears?
thoughts?
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 11-03-2014, 02:22 PM   #2
jholley
jholley's Avatar
Re: let's talk, Posi.
I have an Eaton posi unit with 3.42 Jeg's gears in my '85 I'm pretty happy with.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 11-03-2014, 07:01 PM   #3
c10454
I also have an Eaton posi unit, quiet and lights up both tires on demand. 3:73 gears with a stock 454. I really like the 3:73's but an overdrive trans is in my near future.
c10454 is offline   Reply With Quote
Old 11-03-2014, 08:14 PM   #4
slowcpe
slowcpe's Avatar
Eaton definitely seems to be the popular choice. I will be adding one to my 12 bolt this winter to help to put the power of my 6.0 to the ground.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 11-03-2014, 08:19 PM   #5
greg64
greg64's Avatar
I've had an eaton posi in my 12 bolt with 3.42s for 7 years. Works great, not annoying at all ( no chattering). I can really tell it's working in snow and on gravel because the one wheel slips a bit on tight corners, leaving a pattern.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 11-03-2014, 08:24 PM   #6
dfrank
dfrank's Avatar
Definitely an Eaton posi with a set of richmond gears. Don't cheap out on the gears!! Ask me how I know. Lol
dfrank is offline   Reply With Quote
Old 11-03-2014, 09:19 PM   #7
SkinnyG
SkinnyG's Avatar
The Eaton Posi - is this a cone type? Anyone use a Torsen/Helical style?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 11-04-2014, 08:54 AM   #8
bdiamond
I had an Auburn cone type and didn't like it at all. It worked fine as a posi unit but at low speeds turning, like changing lanes at at a light or pulling into a driveway, it would pop and jerk like the rearend was coming apart. I found out that was just how a cone type worked.
bdiamond is offline   Reply With Quote
Old 11-04-2014, 09:21 AM   #9
IIGW
everyone is saying eaton, is it the clutch type lsd their talking about or the trutrac lsd carrier?
clutches are nice for a light street car, but a big truck id like the trutrac.
IIGW is offline   Reply With Quote
Old 11-07-2014, 02:00 AM   #10
chris989
That is odd, I have run many Auburns and found them smooth as silk. Maybe something was defective in your?? Are you still running it?
chris989 is offline   Reply With Quote
Old 11-07-2014, 08:55 AM   #11
Rich84
Rich84's Avatar
I have an Auburn as well..No complaints.Mild street truck.
Rich84 is offline   Reply With Quote
Old 11-07-2014, 09:46 AM   #12
Malibuick231
I ran a Auburn with Motive Gears in my last car 800hp driven all the time on the street. Never popped while making a turn and always worked as it should. I did run the GM additive in mine.
1986 C10 sons truck
2005 Harley Davidson Electraglide mine
2014 Mustang GT the wifes
Malibuick231 is offline   Reply With Quote
Old 11-07-2014, 11:26 AM   #13
Caleb
Caleb's Avatar
i got an eaton posi with 4.11 and master install kit for 650 online. worth every penny.
Caleb is offline   Reply With Quote
Old 11-08-2014, 10:11 AM   #14
homemade87
Auburn for me. Never a problem and smooth.
I have an auburn and has always worked perfect. You do have to have the proper additive. If you buy the fluid off the shelf with it added to it, it is not enough . You will have to add the gm additive as well or it can pop and make some noise . It has to have the proper additive.
homemade87 is offline   Reply With Quote
Old 11-08-2014, 12:25 PM   #15
Dunenutt
Newbee
Dunenutt's Avatar
The helical style is called a Tru Trac. Made by Eaton/Detroit. I use them on everything I build. Feels 100% open until it engages. No tire wear or hopping. The only drawback is if you lift a tire, sometimes it wont engage. Tap the E-brake a bit, and it engages quick.
I have installed them on street vehicles, and several 4x4's ( front and rear). Beat them like the owed me money, and never failed. I have broken several Detroit lockers though.
Dunenutt is offline   Reply With Quote
Old 11-08-2014, 12:38 PM   #16
Dunenutt
Newbee
Dunenutt's Avatar
I use Torq-Line gears, made by US-Gear. USA made, pattern awesome, and never had an issue with them. Check the out on the net.
Old 11-08-2014, 02:50 PM   #17
SkinnyG
SkinnyG's Avatar
What is the Tru-Trac like in the dead of winter on ice? I don't really want a Low-Side-Detector (LSD).
Old 11-08-2014, 07:48 PM   #18
Dunenutt
Newbee
Dunenutt's Avatar
Any posi sucks on ice period!
Old 11-08-2014, 08:18 PM   #19
greg64
greg64's Avatar
I've got the eaton posi, and on snow and ice I love it. However, I have proper winter tires that are studded.
Greg
