11-03-2014, 01:53 PM | #1 |
New Project- 1966 C-10 Service Truck
Just purchased this 1966 C10 Service Truck a few days ago. The bed is what makes it so different! Got it all cleaned and buffed out and it fired right up with a fresh battery and a little starting fluid. Ran out of motivation yesterday (dang you NFL Sundays!!). Going to clean the carb, new plugs, points, change all the fluids, etc in the next week or so. May be hard to tell in the pics, but the before and after is a huge difference. Paint buffed out pretty good! Next up is a CPP 3"/4" drop and a set of 20" wheels with grey centers. Still trying to figure out the right wheel for this "work truck". 6 lug wheels are slim pickings it seems. Open to wheel suggestions if you have them.
Before: After: |
11-03-2014, 02:38 PM | #2 |
Re: New Project- 1966 C-10 Service Truck
Pretty solid looking truck.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-03-2014, 04:00 PM | #3 |
It has a little rust in the normal locations, but overall it is in real good shape.
11-03-2014, 04:50 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
That's cool! I like it!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-03-2014, 06:07 PM | #5 |
That's a cool truck.
It only has original paint once |
11-03-2014, 06:30 PM | #6 |
But Found Her 25yrs Later!
i totally dig service box trucks.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
11-04-2014, 08:57 AM | #7 |
Looks great the way it is. How about just painting the wheels that's on it to match?
11-04-2014, 10:12 AM | #8 |
That's awesome!
11-04-2014, 11:02 AM | #9 |
Moderator
I think the steel rally 4x4 wheels with caps and rings would look perfect. They are easy to find, and not expensive.
11-04-2014, 11:40 AM | #10 |
Chevy addict
Cool truck, no drop, it's totally cool the way it is, wheels and all
11-04-2014, 11:45 AM | #11 |
Jacksonville craigslist? You beat me to it. I sent him an email and was ready to make the trip down and it was already gone in less than 24 hours. Is it as solid as it looks? Congrats, can't wait to see this build!
11-04-2014, 09:22 PM | #12 |
Am I seeing things or is that a short bed? I like the fact that you want to keep the service body. You used to see many of those but not so much anymore.
11-04-2014, 10:00 PM | #13 |
No not Jacksonville. Bought it from an old timer the next county over. Evidently he has been trying to sale it for a year or so!
11-04-2014, 10:01 PM | #14 |
11-04-2014, 11:02 PM | #15 |
What A Beauty, I Worked For Miller Beer And Had a Short Bed Hunter Green Service Truck Like This,
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
11-05-2014, 07:41 AM | #16 |
sweet truck! I would rather sit and watch a ford rust then nfl myself.
11-05-2014, 08:56 AM | #17 |
I dig it, nice score
"El Jerry" '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
11-05-2014, 09:26 AM | #18 | |
I like steel wheels and hubcaps for something like this..especially if you are going to lower it. |
11-06-2014, 10:17 AM | #19 |
11-10-2014, 10:12 AM | #20 |
Busy day yesterday. Rebuilt the carb, replaced all the fuel lines and filter under the hood, replaced all the heater and radiator hoses, replaced some vacuum lines, installed new aluminium Champion radiator. Fired right up and idles great! Replaced the headlight switch but still no headlights even though everything else works; hopefully a new dimmer switch and some new grounds will solve that.
I ordered the CPP 3"/4" spring kit with: shocks, rear relocation brackets, adjustable pan-hard bar, and front shock reinforcement brackets; they should be here this week. It will be another busy weekend coming up. The truck sits to high for my taste, this should solve that problem. Its getting there! |
11-10-2014, 10:29 AM | #21 |
You are moving quick, gonna look real nice with that drop!
I didnt see above, what motor do you have? Inline? |
11-10-2014, 12:20 PM | #22 |
Post Whore
Welcome aboard! Sweet truck! I'm liking it! What you got for an engine under the hood?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
11-10-2014, 12:25 PM | #23 |
250 I6, 3 on the column. Should have said that at the top. It seems to be a nice little motor. I still need to change all the fluids before its maiden voyage. I'm anal like that!!!
11-10-2014, 02:31 PM | #24 |
i do like those utility trucks... they just make sense to me.
you've got a great one there to build from. have fun with it... |
11-11-2014, 12:08 PM | #25 |
I'm just glad to be here!
These old service trucks are cool. I have always wanted to do one in a 3/4 or 1 ton and use it as a tow vehicle for my first '65.
The blue that is on this one is nearly if not a match to the blue mine use to be back when it was done in the early 90's
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
