![]() Join Date: Mar 2005
Dash pad interchangeability
A buddy asked this question, and I wasn't 100% sure I had the right answer, so...
Can an early dashpad '73-'80(?) be installed in an '81-'87? I know that the model placard trim, A/C vents, and the outboard edge are different between the two, but can the early pad be bolted in place without hacking it all up?
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Re: Dash pad interchangeability
iirc the metal under there is all the same
Slots go on anything!
Yes, but...
The main sticking point is the position of the light switch/wiper switch placement. You can put the newer pad in an older truck, and use the original dash bezel. The bezel will fit OK at the top. The newer dash bezel will not fit happily with an older dash pad at the top. This is exaggerated if the truck is an 84-up that has the wiper on the dash.
1974 Jimmy- 5.3/4L80e/NP241 |
Agree - the sheetmetal under the dash pad is the same.
However (additionally) installing an early dash pad in a later truck will cover the VIN up in most applications (unless you cut a window in that location). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
