poly cab and core support mounts...I'm stumped!
Did a frame off on my 72 C10 LB. Installed new poly cab mounts followed directions included in kit and double checked correct placement here by reviewing past threads. The kit included core support mounts, i go to install fenders and there is a 1/2-3/4" gap bottom fender and door and 1/8-1/4" top of fender and door..like the front of cab is too low or core support to high..removed core support mounts and the core support is slammed to frame, but fenders now correct uniform gap between fender and door. Anyone seen this problem? Acting like I need to shim front of the can up by 1/2" plus.
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
Re: poly cab and core support mounts...I'm stumped!
Bump
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I picked up somebody abandon project from the PO.
When pulling the front clip off I noticed he has (2) 1/4 spacers under the front of the cab on his new cab mounts he installed. |
#4 | |
Check out this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=296953 Just to be sure, you are not running a 67-68 front end, are you? |
I cut the rad support rubbers in half and everything worked out
![]() Join Date: Apr 2010
Might want to take a few pictures and show us what you have!
I guess I was afraid to say it but the same thing happened to me. I was in a hurry so I just put the spacers under my cab and I probably should have just cut the radiator poly's. It seems now that my ladder rack is a fair bit closer to the top of the cab looking back at old pics with the smashed rubber mounts. I guess the ones they send are too large. Mine is 4x4 BTW.
Hate to dig this up but I put poly bushings in my c20 and now the rear of the cab is too high, the lines don't match with the bed lines. Do they make the taller rear poly bushings too tall?
1968 LWB C20 / AC / Wood Bed |
![]() ![]() Join Date: Sep 2008
I ordered poly bushings the first time, but chickened out and didn't put them on.
I reordered factory style bushings for my 4x4 and everything worked great.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
Your radiator core support is sitting on the two new rubber bushings, right?
These trucks have many variables when it comes to lining body panels up. I had to open up a couple of holes in the core support and grill brackets with a die grinder and still I have the passenger side outer fender dipping down a bit. I have decided to let that go for now and maybe let a body shop fix that. My attempts to get an experienced forum member to come to my house to help me do this all came to naught. |
