Old 11-03-2014, 06:53 PM   #1
Ratpin
Ratpin's Avatar
Leaf spring drop shackles amount of drop
I am getting ready to order some leaf spring drop shackles for my '64 GMC. I see Performanceonline.com sells a 2" drop shackle for $69, While ECE list there drop shackle as 1.5" for $59.
Are these the same part? and if so why is one listed as 2" and the other 1.5"?
Anyone have these to confirm the amount of drop? I want the one that will give the most lowering, but I have a feeling they are the same part.
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 11-03-2014, 07:57 PM   #2
newbe351
Re: Leaf spring drop shackles amount of drop
I had the ECE shackles for a while. Every time I hit a bump, they would bottom out on the underside of the bed (not every time, but often enough). I would imagine a 2" drop would be worse. Finally just bought the drop leaf springs from ECE (4" to go with drop spindles and drop coils up front). All is well.....
newbe351 is offline   Reply With Quote
Old 11-03-2014, 08:09 PM   #3
Ratpin
Ratpin's Avatar
Do you have a truck or suburban? I wonder if the sub will have clearance issues too. That's the first I've heard of them having clearance problems.
Old 11-04-2014, 12:40 PM   #4
newbe351
I had a long bed fleetside. Not sure if the 351E trucks were different than others, but I had nine leafs vs. seven. Don't know if that had anything to do with it, but the top of the shackle was only a couple of inches from the underside of the bed and would hit the bed on hard bumps. As the wood was original (old), I didn’t care but it was dinging it up pretty good. After I started fixing things up and replacing suspension components and bed wood, etc. I went with the lowered leaf springs so things wouldn't knock together....
Old 11-04-2014, 12:56 PM   #5
Ratpin
Ratpin's Avatar
Interesting. My suburban has seven leafs and I planned on removing the 3 smallest leafs if and when I install the shackles.
