anyone have the wiring diagram or color codes?
well as you all know trying to continue or finish up a project from the previous owner is always going to be a pain or figure out what they are doing.
long story short, it looks like they attempted to redo the wirings and i'm left with the headlights not working and turn signals don't blink (for some reason when the headlight switch is on both left/right signal is on at the same time and when I try to use the turn signal, one of them turns off) Sounds like I have some issues with the ground wires? the thing that is hard is there are tons of wires cut and left dangling and I don't know what is what. any input would be greatly appreciated! I want to be able to start driving this truck at night and use the turn signals already! lol! |
Re: anyone have the wiring diagram or color codes?
oh boy...so this is what i found:
i don't even know where to start with this?!? |
Not sure what you are working with, but my truck was hacked away by my Gramps, who was an electrician. Over 20 splices alone in the cab. So I will be going with this kit:
http://www.americanautowire.com/shop...-1969-72-truck Nothing but great things to be heard on AAW and this kit. Just throwing it as an option and their instructions are clear and easy to follow. Good luck!
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
![]() Join Date: Feb 2002
Crazy Chevy10:
You don't have a '67, do you?
I have a 68' but it looks like they changed the fenders out and went with a total different wiring from another year? the reason why I said that is because I was told I have 69' fenders without the sidemarkers. and it looks like these wirings are from a gmc? because i see another set of what looks like headlight plugs? this thing is a mess
#6 | |
A true '68 has no lights in the fenders -- side markers are reflectors only. '67s have no cut outs for markers or lights. Some '69s may have had working side marker lights, and this included turn signal indicators by '71.
You might post some pics so we know if you're working on a new harness, old, or if new, which one(s)...
If you have an originalish harness, there should be some stickies or a diagram on the site. For new, you need the maker's color code and schematic. As always, you need grounds (return path to battery), which by convention aren't on the drawings. You just have to know... ![]() |
member #16
![]() Join Date: Dec 1999
Here's a link with some hi-resolution pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Lot of diagrams links in here, many online free be heads up for model differences, etc.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
