11-03-2014, 08:57 PM | #1 |
Got-DANG Pop Rivets
I almost threw a vent window through my windshield tonight. I'm redoing the gaskets (Steele Rubber this time) and I want to do it the right way and use rivets on the division post. I'm only able to work on this by myself. What's the easiest way to do this? I'm open to buying an extra tool to do this job, as I want it done right.
11-03-2014, 09:07 PM | #2 |
Never Ending Projects
Re: Got-DANG Pop Rivets
Seems everything I read, you need like 5 hands to do this. LOL No help and hope you can get it done.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-03-2014, 11:18 PM | #3 |
1961 crewcab
check these threads out-
http://67-72chevytrucks.com/vboard/s...d.php?t=351471 http://67-72chevytrucks.com/vboard/s...d.php?t=599586
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-04-2014, 12:05 AM | #4 |
Hollister Road Co.
I would go to
Herbert A. Heitman co 1422 McCarty Drive Houston, Texas. 77029 they do brake relining among other things. Take it over there and see if they can rivet it for you. I wouldn't call them they may just say no on the phone but if they saw it they may see its an easy job on a foot riveter that can do car brakes |
11-04-2014, 01:06 AM | #5 |
I did mine on the suburban and don't remember it being that bad. I used the repop rivets with a hammer and block or punch and they worked, windows never blew out at 110 MPH.
11-04-2014, 08:27 AM | #6 |
Jonzcustomshop , ive been using the first article for referece. he mentioned one or two tools that could be used to make the job look professional, but never mentioned how to aquire them. what i may be able to do is put the vent window in a vice (softly) and put the 1/4" extension underneath to where its standing on the ground, and also supporting the rivet underneath. i managed to get one rivet in place last night, but because i didnt have a straigt shot at it with the hammer, i made the rivet crush crooked :-(
dwcsr, i may give that a shot friday, being as that i will have the day off. i would really like to find something that i can order to do it myself though, i try to do as much as i can on my own. LT1 Burb, how did you do the one in the corner, alll the way at the top? you have to have a straight shot at these for them to set correctly, dont you? from the second article that Jonzcustomshop posted, the part that crushes goes toward the glass, im not seeing how that one is able to be done. |
11-04-2014, 10:15 AM | #7 |
I honestly wish I could remember but it was probably 8 years ago, I am pretty sure I used a vise and hit them with a hammer and punch.
11-04-2014, 10:26 AM | #8 |
Ill try and play around with it a little more when i get home, but i would really like some sort of tool to assist in this. With the one rivet i tried to set last night, it didnt work out too well for me.
11-04-2014, 02:16 PM | #9 |
SIR
try using a smal "dremmel" cut off wheel to remove the rivet take a standard rivet gun to replace it ...you may have to grind down the tip of the gun..(narrow it down to fit the channel) and put in a new rivet...
66long low fleet http://community.webshots.com/user/LVNR66 |
11-04-2014, 02:42 PM | #10 |
SIR, are you saying to use a different type of rivet or modify the rivets that ive gotten from LMC?
11-04-2014, 02:43 PM | #11 |
i ordered the rivet kit from LMC, and im assuming it uses the same size rivets as what was from the factory.
11-04-2014, 04:25 PM | #12 |
i think i may just use pop rivets. see how that turns out. wish me luck guys.
11-04-2014, 08:06 PM | #13 |
This is about the cheapest rivet tool you can get and Im not sure it will work http://www.agrisupply.com/c-rivet-to...05/&sid=&eid=/
11-04-2014, 08:20 PM | #14 |
Alan's write up is the one I referenced… I was able to do it with a rivet tool, punch, vise and hammer… Good Luck!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
11-04-2014, 08:50 PM | #15 |
Ok, used a pop rivet gun and some 1/4" (I believe) rivets and they worked perfectly. Im happy!
11-04-2014, 09:23 PM | #16 | |
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
05-17-2016, 11:20 AM | #17 |
Bringing up an old post because I'm about to tackle the wing/vent windows on my truck. I've been looking for a tool to do this besides the punch type that at least half the post I read say isn't all that great. I'm just asking if that 'farm' rivet setting tool actually worked well for setting the wing vent rivets. Did it work for all of them or only the pivot rivet. I don't really mind spending a little for a tool that will do the job right and I won't have to tear down my windows again in a couple of years to replace sloppy rivets.
Thanks! Brian |
05-17-2016, 10:32 PM | #18 |
Not to discourage you, but I gave up and saved my money for the new vent assemblies . Took 6 months, but worth it, and I should install them this month. Yes, I'll take a lot of pictures.
http://s1299.photobucket.com/user/jb...23904108567829 |
05-17-2016, 11:58 PM | #19 |
meowMEOWmeowMEOW
I used rivets on mine, it was fiddly but I managed. Here's my little writeup on the hacksperience.
http://67-72chevytrucks.com/vboard/s...d.php?t=537639
