67-68 Emergency Brake Cover Install
i picked up a cover for the e-brake in my 67 a while back. My truck did not originally have one but I would like to install it now. I can see where it will need to go, and how it will need two holes drilled. I would like it to look as original as possible, so I am looking for fastener info. Is it held on with self-tapping screws? Bolts and nuts? Some other type of fastener? It looks like there is not good access to the back so I am thinking something that does not require access from the rear.
Thanks in advance. Adam |
Re: 67-68 Emergency Brake Cover Install
It takes two screws just like the ones that hold the column seal at the dash bezel. They have the large flat pan head and 1/2 long or less
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Please post as pic of this if you can (anybody). I don't even know what an e-brake cover is.
1967 GMC SWB 383 Stroker w/Saginaw 4sp 1979 Chev C30 Scottsdale Flatbed 350 4sp 2000 Chev 3500 Flatbed 454 Automatic 1978 GMC 6500 Flatbed Dump 366 5sp + 2sp 1965 Chev K10 LWB 230 4sp 1985 Chev K30 Flatbed 350 4sp |
#5 | |
Thanks. |
Self tapping. Let me see if I have one for you to see
#7 | |
Don't think it does.
I believe they only came on CST's. I see they are now available as reproductions for about $30. I thought it would be a nice dress-up item and was somewhat rare when I bought this some time back.
It is in deed held on by self tapping screws and a CST thing. Here's my under/over shot. Sorry about the blurriness, it is past 9 and dark out after all
'68 C10 SWB '85 K30 Blazer |
Very helpful! Thanks!
I noticed it looks like yours has bolts holding the column cover and brake cover vs. mine has screws holding the column cover. I wonder if that is a change from 67 to 68. Unless I just cant see well in the pic and they actually are screws. I think I will pull a column cover screw and try to match it up for my brake cover. Thanks again for the help! Adam |
