Old 11-04-2014, 01:31 AM   #1
crazychevyc10
What's needed to convert to a powersteering setup?
I want to convert to a powersteering from manual now...what is needed to accomplish that?
I found an ad for for a powersteering box with the pitman arm and pulleys. Is there anything else I need to go with it?
crazychevyc10 is offline   Reply With Quote
Old 11-04-2014, 01:45 AM   #2
kwmech
Re: What's needed to convert to a powersteering setup?
If that is a kit, that should be all you need aside from a belt and fluid, some grade 8 7/16'' bolts to put the box on the frame and a few other bolts. Kit should have the matching crankshaft pulley. What year we working on?
kwmech is online now   Reply With Quote
Old 11-04-2014, 01:49 AM   #3
crazychevyc10
No, it's some parts on craigslist this guy is selling:
http://sfbay.craigslist.org/eby/pts/4742970483.html
What do you guys think?
Old 11-04-2014, 01:51 AM   #4
leddzepp
Moderator
leddzepp's Avatar
Brackets, pump, hoses, power steering box, belt, pump/crankshaft pulleys.
Big block, small block, inline 6, V6, short or long water pump if a V8? There are a LOT of variables to consider.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-04-2014, 01:53 AM   #5
crazychevyc10
I have a small block 350 and a short water pump I believe
Old 11-04-2014, 12:47 PM   #6
70blackfish
go to the junkyard.....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
