11-04-2014, 05:55 AM | #1 |
Steering Alignment settings for 82 K10?
Hi Guys
Does anyone know what the steering alignment settings are for a 1982 Chevy K10? Its a 4x4 6.2 diesel at stock height. Not sure what is adjustable but caster, camber toe settings?? Cheers Mike |
11-04-2014, 08:29 AM | #2 |
Re: Steering Alignment settings for 82 K10?
Technically, just toe. You want slightly toe'd in, with the intent that they would be straight going down the road, due to compliance in the system. Off the top of my head I think the spec was 1/8" to 1/4" toe in.
Not so technically, you can adjust caster with tapered shims between the spring and the axle seat. You want as much as you feel comfortable putting in there. We used to run as much as 10 degrees, which will give you very nice stable on center feel. Camber is not intended to be adjustable from the factory but there are tapered kingpins available in the aftermarket. You have to be pretty hardcore to pursue that option. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-04-2014, 01:01 PM | #3 |
Cheers Keith, I'll stick to adjusting the toe! Just dont want to wear out tyres!
Mike |
11-04-2014, 01:24 PM | #4 | |
The problem with tapered adjuster sleeves for your upper ball joints is the pre-load torque. Instead of setting it to 50 ft-lbs, you would need to turn it more or less to get your desired angle....which inevitably put more or less pressure on the upper ball joint. I experimented with it a lot, but finally took them out and just used the standard ones.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
11-08-2014, 04:13 PM | #5 |
This is the beast....photos taken in Larne, Co Antrim, N.Ireland!!
