11-04-2014, 01:33 PM | #1 |
C10 CLUB Y QUE!
Accuair/Porterbuilt
Looking for tips on install of accuair on a porterbuilt dropmemeber
1. Best place to place the VU4. Does it need to be in the middle? 2. elevel best place to install the elevel? 3. what other stuff does one need to install elevels.? |
11-04-2014, 02:42 PM | #2 |
C10 CLUB Y QUE!
Re: Accuair/Porterbuilt
shaft collars for the front and rear.
Go to www.mcmaster.com and look for these part numbers. Should be what you are needing. I am running Porterbuilt on front and rear and these worked perfect for me. Part# 6436K74 2 Each Two-piece Clamp-on Shaft Collar, Aluminum, 1-1/4" Bore, 2-1/16" Od, 1/2" Width Part # 6436K76 2 Each Two-piece Clamp-on Shaft Collar, Aluminum, 2" Bore, 3"outside Diameter, 11/16"width |
11-04-2014, 08:31 PM | #3 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-04-2014, 08:58 PM | #4 |
C10 CLUB Y QUE!
I haven't mounted them yet. But I'll post other people's pic
11-05-2014, 09:36 AM | #5 |
Thanks. Just wondering if attaching the collar to the upper arm might be better?
11-09-2014, 12:55 PM | #6 |
How about these? Cheaper than the McMaster Carr ones.
I posted these in another thread. I found these on Instagram but haven't seen them around here. They aren't on http://www.littleshopmfg.com yet but the guys over there were very helpful and got them sent fast. If I remember right the whole set was 25 bux or so shipped. |
11-09-2014, 02:08 PM | #7 |
The manifold can be placed wherever. I like in the cab behind the seats for everything so no worries about weather.
Tank and comp can go outside, you really only need one line in anyways. Fast enough for me |
11-09-2014, 02:40 PM | #8 | |
C10 CLUB Y QUE!
I was thinking the same thing about the manifold in the cab. Bu I worried about the exhaust noise |
11-09-2014, 02:44 PM | #9 |
