how much drop before a cnotch?
How far can I drop my rear end before I need a cnotch? I want to drop 5" but do not want to notch it.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: how much drop before a cnotch?
kinda depends on your tire size, leaf or coil and fleet or step.
rule of thumb is 4-5".
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I have 4 inch springs and have no problem.
66 shorty ![]() |
![]() Join Date: Feb 2014
Forgive me if this is a stupid question but why does it matter if it's a fleet or step? Can one be lowered more than the other? Just curious because I have a step with coils.
![]() Join Date: May 2007
5" rear empty no problem but I use as a truck had to add c-notch, axle was hitting the frame.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Go bags and you can adjust. My 62 went at least 5" without issues. Put the springs in look for issues then decide.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
It doesnt really, was just asking for a mental picture along with what tire size you are running.
I have a 66" stepside on cpp 4" drop springs and 2" lowering blocks with no c-notch. Does not bottom out. Fuel cell is located in the rear. I never have any load in it, but I'm pretty sure if I were to put load in it, rearend will bump the bump stop.
I just did 5" rear drop (Coil springs) and dont see that Ill need a C. Though I plan to USE... my truck, so I may find a heavier load may warrant a c-notch eventually.
I dont happen to have a picture of the room between the bump stops and axle now, but it was a good 3-4" still. I figured with no heavy load and not hauling stuff in the back on a daily basis that it will be enough for the occasional pothole travel needed. ![]() |
Thank you for all the replies. I have decided to go ahead and put one in. Just in case later I want to lower it more. thank you all again.
