What is this and why is it here
Looking into the rear of the front fenderwell. This is some sort of cover for the inner fender. This is the only rust of any concern I have found on this entire truck. What is this for? Where can I buy a replacement for the right and left side? And the ultimate question, why in the world did GM make this out of such a crappy material so it would rust like this???
Active Member
![]() Join Date: Oct 2012
Re: What is this and why is it here
Not sure but i have that on my 81 as well... And i'd like to know as well.
Slots go on anything!
It is a reinforcement for the inner fender. The bolt that goes through it supports the inner fender by holding it to the cab. The only way to replace the reinforcement is to either drill it off of another inner fender or replace the inner alltogether.
1974 Jimmy- 5.3/4L80e/NP241 |
![]() Join Date: Jul 2014
So your saying the extra piece of metal (reinforcement tab) comes on the new tubs? These are only like $40 a piece and if the tab I'd rusted you gotta think there is more rot somewhere else on the tub.
http://www.classicparts.com/1973-80-.../#.VFlvI2K9KK0 |
![]() Join Date: Aug 2004
That piece dose not come with the inner fender. I have two nos inner and that piece dose not come with. Most be a separate part number for it. John
#6 | |
Surely someone on here has pics of this disassembled... |
In all of the square inner fenders I have seen that reinforcement appears to be part of the inner fender itself - maybe factory spot welded. Keith should be able to provide the final verdict.
If you replace the inner fenders you should seek advice on the quality of aftermarket inner fenders. I have not heard good things about fit and finish and thickness of the aftermarket sheet metal. Also, shipping on these parts is a lot since they are very large (but not very heavy.) Damage in shipment is typical and LMC states so in their listings. Good used OEM is always my choice if possible. |
![]() Join Date: Jun 2009
It is hard to find nice ones that don't have rust somewhere on the 1980 and earlier trucks. I had a customer that needed a pair and I pulled a total of 6 before I got him a nice pair. A lot will look good until you remove them then you see the rust on the inside of that brace. These were all Arizona trucks too! Definitely a design flaw!
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
I repaired the rust home through and behind both of mine, but did not reinstall them. Since they do not "seal," they will collect crud and just rust through again - so I did not replace them. I will find out how important they are once something fails (the inner fender itself?).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
I have no time for this
I have never installed a oem set of inner fenders that didn't have that brace on them.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
I will have to go look again, but do not think I saw them on my nos pair, will report back. John
#13 |
Here in the deep south desert most of the inner fenders I see are 81-87 and they are usually rust free, including this brace, but they also usually have dents, dings, extra holes, etc. It should be noted that a lot of these old squares out here originally came from the rust belt when their owners relocated to the sunbelt, so they came here with rust to start with. I did get a mint pair off a Suburban but decided not to use them, since mine were not as bad as I thought - they are gathering dust in the shed now.
#14 |
Up here in the rust belt, mine rusted off around the bolt. There is a tab on the cab they bolt to, and around that tab a square-c-shaped hole around the tab. I just patched it and didn't worry about adding anything to the inner fender as a means of support. Probably used more as a noise eliminator rather than true reenforcement (just count how many bolts hold on the inner fender, it ain't going anywhere, but the cab/inner fender touching can produce noise.
Alex. |
#15 |
78K & 79C Jimmys
Its a road spray area,starts the rust on the bolt,and it spreads.
it usually is a fix area up here,most years. I replaced the whole inners and just paint before winter
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
