Old 11-04-2014, 08:45 PM   #1
sgr60
"New" Truck - first two leaks found
Just a few days with my "new" '84 K20 and I've already got some questions.
Now that the truck is sitting in a nice clean garage (rather than the field I bought it out of) I've noticed two leaks so far - one oil and the other power steering fluid.
I took a photo from the top down of the area of each leak. Any thoughts on what the culprits might be?
Oil leak:
Power steering leak:
Thanks!
sgr60 is offline   Reply With Quote
Old 11-04-2014, 09:42 PM   #2
mrolds88
Re: "New" Truck - first two leaks found
Not sure about exactly where its leaking on the steering, but on the engine, I'm looking at the rear intake seal and valve covers. I would suggest you either power wash or take it to the car wash and blast the leakage off and recheck afterwards.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-04-2014, 09:59 PM   #3
sgr60
I definitely need to get it cleaned up - in addition to the oil, there is 30 years of grime caked onto all of the drivetrain components underneath.
Is it OK to "blast" the water in that area - so close to the distributor?
'84 K20 350/465/208
Old 11-04-2014, 10:44 PM   #4
mrolds88
Yes, just be careful. If need be, cover the cap with a plastic bag.
93 K2500 xcab 6.5TD
Old 11-05-2014, 01:44 AM   #5
LilD
LilD's Avatar
Power steering could be like many others I read about researching the issue with mine. Input shaft seal.
LilD is offline   Reply With Quote
Old 12-07-2014, 08:25 PM   #6
sgr60
I've made some headway on identifying the oil leak. I've gotten the area cleaned up quite a bit, and also changed out the valve cover gaskets along with doing an oil change. It looks like I now have two leaks - it might be just one, but it looks like two.
First, you can see oil dripping here - the plug wires are new, so that oil on them has dripped onto them from somewhere. It looks like it might be coming from the plug with all the wires coming out of it. What is this? Two photos below:
Next, there is fluid dripping down around the transmission bell housing (I just changed that fluid today as well) - I can't tell if it's engine oil from somewhere, or it's a leak from the tranny. Thoughts? Photo below:
Thanks for the help.
'84 K20 350/465/208
Old 12-07-2014, 09:30 PM   #7
Just call me Sean
Just call me Sean's Avatar
You've got oil top to bottom. Most likely valve covers.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-07-2014, 10:43 PM   #8
sgr60
I put in new valve cover gaskets and the smoking that I was previously getting from oil on the exhaust manifolds has stopped - so I was thinking that the leak there had stopped. It's possible that I'm wrong, but I was thinking the problem was elsewhere.
'84 K20 350/465/208
Old 12-07-2014, 10:52 PM   #9
mattybilt79
That round plug should be the oil pressure sender. Looks like rear main is leaking if its coming out of bell housing. I would pull the dust cover off and see if the flywheel and clutch are wet. Could also have oil coming from intake to block seal at rear of motor and possibly the distributor holeand still possible valve cover leak if gasket slipped when you put them in or if valve covers are bent out of shape. The steering leak is more than likely the input seal just about every truck I've owned has leaked there.
85 3+3 with a tee-pee
mattybilt79 is offline   Reply With Quote
Old 12-07-2014, 11:04 PM   #10
sgr60
Curious - why does the oil pressure sender have so many wires. My oil pressure gauge only works intermittently as it is... Maybe I should replace that?
The dust cover was actually out when I went under to take the photos - I pushed it back in with a screwdriver - now sure how long it was loose for.
The oil leak is very slow, I may just live with it for the time being, I have a lot of other things I need to do before I can think about what would be involved with replacing the rear main seal.
As far as the steering leak, I'm going to replace the steering shaft and power steering gear next weekend, so that should solve that - that's a much bigger leak. Seems like a pretty straightforward job.
'84 K20 350/465/208
Old 12-07-2014, 11:21 PM   #11
mattybilt79
I don't know why some have that 3 wire plug while others have 1. Seems like a lot of stuff changed in the mid 80s with electrical vacuum and other systems on Chevy's and gmcs.
Old 12-07-2014, 11:25 PM   #12
Just call me Sean
That three wire oil pressure sensor is for the choke. Yes, it's for the choke. The one for the gauge is behind the distributor and has only one wire like all the rest.
Old 12-07-2014, 11:31 PM   #13
sgr60
Interesting - it just gets more complicated as I get deeper into it
Guess I'll have to keep digging and try to better understand the wiring diagrams...
'84 K20 350/465/208
Old 12-07-2014, 11:40 PM   #14
Just call me Sean
It's pretty simple, I'm used to tracing fuel injected diagrams. Plus I went through all this on my '83. None of that was hooked up, some of it still isn't.
Old 12-08-2014, 05:46 AM   #15
donut
donut's Avatar
The oil on the bell housing could also be coming from the rear of the intake manifold.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 12-09-2014, 10:15 PM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
some times the valve covers need to be flattened out before reusing it.
(the edge/lip the gasket sits on)
make sure the oil sensor it self isn't cracked or loose leaking down the back.
do you have a working PCV valve?
covers sealed to tight will blow it (gasket)back out,with blowby
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-10-2014, 01:28 AM   #17
mrolds88
With the oil on the bellhousing and the plug wires, especially the way they are routed, I still believe you have a rear intake leak.
93 K2500 xcab 6.5TD
Old 12-10-2014, 02:04 AM   #18
sgr60
I was planning on replacing the intake manifold down the road, so if that's the source of the leak then hopefully I'll be able to take care of it.
'84 K20 350/465/208
Old 12-10-2014, 06:32 AM   #19
Your41Plague12
Your41Plague12's Avatar
The round plug above the oil filter is for the oil pressure switch. Like previously mentioned, it's wired into the choke circuit. It won't let the electric choke close unless there is oil pressure, essentially just to let you leave the key on without the choke engaging. It my have to crank for an extra second until the choke sets on the first start of a cold morning, but it's a good idea in theory. Mine was disconnected when I got my truck, but I hooked it back up and it works great.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
