11-05-2014, 03:27 PM | #1 |
Brake pedal/light adjustment
Is it possible to adjust the amount of brake pedal travel necessary to trigger the brake lights? If so, how? I have poked around the brake switch, but it's awkward location made it impossible to see what I was doing.
I was stopped in traffic this morning and a big Dodge pickup with chrome grill was behind me. I could see the reflection of my truck in the grill and noticed that my brake lights weren't on. I pressed the brake pedal harder and the lights turned on, I went back to my "resting" brake pressure and they turned off again. I'd like the brake lights to light up with light pressure on the pedal so that I don't have to hold the pedal down with an unnecessary amount of force at every red light, or worry that the lights aren't turning on when I lightly tap the brakes while moving. Thanks in Advance! |
11-05-2014, 03:42 PM | #2 |
Re: Brake pedal/light adjustment
The brake light switch itself is adjustable. It can tighten or loosen and be adjusted closer or further away in order to accommodate your pedal travel needs. There's two jam nuts that hold it in place. Unplug it and you should see what I mean.
You'd just loosen the nuts, and screw it in closer to the bracket thingy so it will engage sooner. Once you are satisfied that it works properly, tighten the jam nuts again and plug the switch back in. |
11-05-2014, 03:51 PM | #3 | |
11-06-2014, 12:05 AM | #4 |
Who Changed This?
No, there is a jam nut on each side. Loosen the one and tighten the other. Loosening the one closest to the brake arm will cause the switch to close the circuit sooner, meaning that the light will come on with lighter pressure, since the switch is moved away from the brake arm sooner. Be sure to snug the one on the other side down so that the switch doesn't flop around.
