Old 11-05-2014, 06:45 PM   #1
KMC3420
KMC3420's Avatar
Fuel pump and filter
Just don't want to buy parts twice so looking for some advice on the suggested filter and pump. I am planning on going with a boyds tank, but using an external fuel pump. What are your thoughts on these. Wix fuel Filter 33737: http://www.ebay.com/itm/121474818692...%3AMEBIDX%3AIT and using this pump: Walbro 255LPH: http://www.ebay.com/itm/380876492468...%3AMEBIDX%3AIT
Or there is this option: http://www.ebay.com/itm/400794493448...%3AMEBIDX%3AIT
My motor is a 02 5.3, so it has the return line coming from the fuel rail.
Thanks for any help.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 11-05-2014, 08:25 PM   #2
clinebarger
Re: Fuel pump and filter
If you going to buy a tank, Why not go Internal Fuel Pump?
clinebarger is offline   Reply With Quote
Old 11-06-2014, 12:16 AM   #3
KMC3420
KMC3420's Avatar
I thought about it and still might. Just trying to weigh my options. If I for sure go with the Boyd's tank I will go with in tank. What are the advantages of each? A external pump would be easier to change if need be.
Keagan
Old 11-06-2014, 12:37 AM   #4
ls1nova71
ls1nova71's Avatar
External pumps are easier to change, but internal dont go out as much since they are in the tank and cooled by the fuel. Also electric fuel pumps are designed to push fuel, not pull, so internal is better for that also. I too would go internal pump if you are buying a custom made tank. Also, since you have a return line on your fuel rail, you don't need the Corvette filter/regulator. Just get a regular filter and run the feed and return lines from the tank.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-06-2014, 12:42 AM   #5
KMC3420
KMC3420's Avatar
I'll do some research on the filters that are being used on the ls swaps. Any filter that seems to be better than most?
Keagan
Old 11-06-2014, 02:19 PM   #6
Hart_Rod
Hart_Rod's Avatar
+1, 2 and 3.....
As far as fuel filters, I would install a 10 Micron post pump filter with a 100 Micron pre pump filter.
Hart_Rod is offline   Reply With Quote
Old 11-06-2014, 04:30 PM   #7
KMC3420
KMC3420's Avatar
Okay, the search is on, I will find one then post back here what I find. One other question I do have is what about the regulator and filter that is on the fuel rail already?
Keagan
Old 11-06-2014, 05:46 PM   #8
KMC3420
KMC3420's Avatar
It looks like Aeromotive has a few good options for the pre and post filters. Is there any need for a filter on the return line?
Keagan
Old 11-06-2014, 10:35 PM   #9
truckdude239
truckdude239's Avatar
That is just a regulator not filter on rail you do not need a filter on return line
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-06-2014, 11:17 PM   #10
ls1nova71
ls1nova71's Avatar
If you go with an intank pump, you don't need a pre-filter, that's what the sock on the pump is for. Just get a filter for between the pump and rail on the feed side. Leave the regulator on the rail alone and let it do it's job. Just run the return line back to the tank and you will be good.
Old 11-07-2014, 12:06 AM   #11
KMC3420
KMC3420's Avatar
Ls1 thanks for that info. After researching seems like that is what all other swaps are using. I am going to go with the Boyd's tank with in tank pump.
Keagan
Old 11-10-2014, 12:05 PM   #12
KMC3420
KMC3420's Avatar
What about this filter?
http://www.summitracing.com/parts/ea...FaxzMgod4nAApQ
Keagan
