Old 11-05-2014, 11:23 PM   #1
SierraMtns
SierraMtns's Avatar
Seat Belt Configuration?
Does anyone have pictures on how the middle lap belt goes in?
I believe the middle belts share the same bolts as the diver/passenger belts. I cant figure out how they bolt in without the bets twisting.
SierraMtns is offline   Reply With Quote
Old 11-06-2014, 11:33 AM   #2
SierraMtns
SierraMtns's Avatar
Re: Seat Belt Configuration?
Anyone? I am hoping to get the belts put in today.
Old 11-06-2014, 11:37 AM   #3
Steve Hafner
Steve Hafner's Avatar
My 70 C-10's middle belts just bolted to the same bolts as the inner, outside belts.
They just came through the seat "crack" and they laid flat like the others.
I think we might have had to use longer bolts though.
What kind of problem are you having ?
Steve Hafner is offline   Reply With Quote
Old 11-06-2014, 11:47 AM   #4
Lee H
Lee H's Avatar
Yes, they share bolts. Sorry, no pictures. I think the center belt goes on top in the stack.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-06-2014, 12:03 PM   #5
SierraMtns
SierraMtns's Avatar
The belts keep twisting. I cant get them to lay flat when I am bolting them in.
Also, I am not sure on the configuration of the middle belt. Which side do the belts go on?
Old 11-07-2014, 01:45 PM   #6
SierraMtns
SierraMtns's Avatar
Bump
Old 11-08-2014, 01:33 PM   #7
OhioDan
OhioDan's Avatar
Thumbs up Re: Seat Belt Configuration?
To bolt in the center seat belts, the bolts should have a longer shoulder to go through both belts. If you don't use the longer shoulders, bolt will bind on belts and twist them.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-08-2014, 05:57 PM   #8
mechanicalman
X2, like OhioDan says.
mechanicalman is offline   Reply With Quote
Old 08-03-2016, 06:00 PM   #9
Cesar Diaz
they do share the bolt
Cesar Diaz is offline   Reply With Quote
