11-06-2014, 12:30 PM | #1 |
Small hub wheels on drum brakes
I hope this is in the right spot. I didn't see a wheel specific forum.
I recently acquired a set of torq thrust st 6 lug wheels for my 70 C10. I pulled one of my rallies off to do a test fit of the wheel and noticed that the hub on the drum is around 4" while the hub on the wheel is around 3". This seems like a bit of an issue and I was curious as to how I might go about resolving it. I'm sure it is related to a new aftermarket wheel vs. old brake design, so I am hoping this is a somewhat common issue with a fairly easy resolution. |
11-10-2014, 12:46 AM | #2 |
Re: Small hub wheels on drum brakes
There are three options : run a 1/4" spacer
Turn down the hub on the axle Machine the hub on the rim I chose to machine the rim on my 24" foose wheels in order to fit on a 68' rearend. The rims were intended to fit newer style 1/2 tons. It worked out perfect. |
11-10-2014, 08:24 AM | #3 |
I had that issue once. Took mine to a machine shop.
11-10-2014, 07:47 PM | #4 |
I had those wheels on my 65. Put the hub in the lathe and turned it down and then pulled the rear axles and turned them to 3.050 also. Left just enough of a lip to register the drums.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-16-2014, 02:51 PM | #5 |
I ended up finding information online on how to increase the bore with a router and rabbeting bit. It turned out great. I had to go 1" deep instead of the 1/2" I planned because the first router I used was junk and allowed the bit to slip. Really easy process and I was able to do all 4 wheels in about an hour. Total cost was less than $100 including a brand new router and now I have a few new tools in my garage. Here's a few photos
Unmodified wheel First cut 1/4" wide (1/2" increase in bore) and 1/4" deep Final product 1/2" wider bore and 1" deep for plenty of clearance. |
