Old 08-16-2003, 12:05 PM   #1
brad20653
Column help
How do i get the shift lever housing off ? im changing the wires in the column ???
Soon to have 68 SWB 350 with Turbo350
brad20653 is offline   Reply With Quote
Old 08-16-2003, 12:28 PM   #2
jef5150
Inline 69
jef5150's Avatar
http://67-72chevytrucks.com/vboard/s...threadid=64003 you dont hafta pull the column cover to change the column wiring,,,,,
jef5150 is offline   Reply With Quote
Old 08-17-2003, 12:52 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used a punch to tap it off.I placed the punch where the 4 way flasher is(that hole) and then on the opposite side where the turn signal lever is.Tap genltly and work from side to side.A little WD40 helps too.
Dude,your doing everything I've just done:p
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
