Old 11-07-2014, 02:06 AM   #1
chris989
14 bolt upgrade
Hello all,
I have an 89 v2500. I am going to swap out the 9.5 14 bolt for a 10.5 14 FF. The donor is from a 92 3500
Is there any hidden secrets about this swap i might be over looking. I hate to sound pessimistic but lately it seems everything i touch costs twice as much and takes twice as long.
chris
chris989 is offline   Reply With Quote
Old 11-07-2014, 02:30 AM   #2
andrewmp6
Re: 14 bolt upgrade
Since its a different body style truck your probably going to have to move the spring perches and shock mounts.
andrewmp6 is offline   Reply With Quote
Old 11-07-2014, 12:03 PM   #3
chris989
Re: 14 bolt upgrade
welding is an easy fix. Knowing GM, I am wondering if i will have metric on one and sae on the other. Things like brake lines. I will crawl under both again and give it a good looking over.
Chris
Old 11-07-2014, 05:11 PM   #4
Jimbo*
Re: 14 bolt upgrade
When you crawl under, break out the tape measure;
If I remember correctly, the wheel mounting surface on a V2500 is 67", and on the 92 model it will be 65". Also, the 92 may well have a D703HD, which is an oddball with 7/8" ring gear offset, as opposed to most D70's 5/8" offset.
The wheel studs should be metric on the 92 rear, and your 89 studs are still standard thread
Jimbo* is offline   Reply With Quote
Old 11-08-2014, 02:08 PM   #5
greg64
greg64's Avatar
Re: 14 bolt upgrade
Jimbo's correct. I researched all this for my 64. There are two different spring pad widths, with the dually axle being narrower, I believe. There is also differences in the wheel mounting surface width. I used a 14 bolt from a 78 3/4 ton, which was a bolt in affair, as far as springs and wheels go. I was trying to stay away from 1 ton stuff, as I remember. The brakes are also considerably different, but any style will work. I switched over to discs in my case.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 11-08-2014, 07:38 PM   #6
BigBlocksRule
Re: 14 bolt upgrade
Why the swap? The semi-floater's axles are bigger than the full floater.
BigBlocksRule is offline   Reply With Quote
Old 11-08-2014, 07:47 PM   #7
mrolds88
Re: 14 bolt upgrade
While the S/F axles may be bigger, they also have to carry the weight of the rig. The F/F axle only has to propel it.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-08-2014, 07:50 PM   #8
BigBlocksRule
Re: 14 bolt upgrade
^ understood, but I have yet to see a 14-bolt semi-floater torn up.
But I did swap a FF into my 2500 that had a SF, mine were similar years and bolted right up, easy swap. I did it more for the factory G80 than anything else, my SF was/is open and already headed for another project.
Old 11-08-2014, 11:07 PM   #9
Ziegelsteinfaust
Re: 14 bolt upgrade
I swapped in a 14SF into my truck because I wanted a light duty 3/4 ton, but it originally had a 14FF. I had to re-do the mounts, and shock tabs. It was easy enough with a grinder, and a welder. Total time 4 hours. So be carefull which one you buy or mods will ensue.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-08-2014, 11:09 PM   #10
Ziegelsteinfaust
Re: 14 bolt upgrade
While the SF is a damn good 3/4 ton rear end, and capable of towing 12,000 pounds. The FF will just last under just about any abuse where the SF will eventually eat the outer bearings alive.
