![]() Join Date: Sep 2002
Is this a stock quad shock setup?
Recently bought an 87 V10 that I am in the process of fixing up. I bought a new set of shocks to install and noticed that the front quad shocks do not appear to stock. By that I mean if u look in the LMC catalogue at the mounting brackets for quad shocks, one is mounted lower that the other. This makes sense as the replacements I got for the front one shock is longer than the other.
After looking them over on the truck I am thinking that someone just threw another set on the front at one time, squeezing it next to the original. They obviously are 2 different shocks, but do appear to be equal length. At this point I think I would be fine with eliminating the quads and just using the standard 2 setup. I wont be lifting, plowing, or doing much off road with it. Any info or opinions would be appreciated. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: Is this a stock quad shock setup?
That looks like the Old Rancho dual shock upgrade. Factory dual shocks have different top mounts, one shock is longer than the other. I would just put a good signle shock on.
I do have factory dual shock on the front of my V3500 (big block w/winch and bumper)
1990 chevy Crewcab K30 454tbi/th400/np205twin stick/14bltFF,eaton posi/D60. 1972 CST K5 350/th350/12blt,eaton posi/D44 1970 K10 SWB 1970 K20 350/th350 |
I have an 87 V10 with factory quad front shocks what you have isn't the same as mine. factory set-up has two separate mounting locations on the frame.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
At the body shop.
![]() Second bracket for a 4wd
" That didnt make it any newer " " Dont antique the equipment " |
my 1984 k10 has dual front shocks (truck came with a 6.2) ill post pictures when i get home today. im starting to think my is an aftermarket setup does anyone have a picture of theirs?
My 83 had them. Yours is definitely aftermarket.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
thanks everyone for their input, goin back to a single setup
I got kyb gr2's on my K20 and it handles great as far as I can tell. My first 4x4, and I removed my sway bar. I got them on special from rock auto for $13 each.
I would only try a dual shock if I had large tires. |
78K & 79C Jimmys
seen in a junkyard
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
