Old 11-07-2014, 01:47 PM   #1
SourTooth307
SourTooth307's Avatar
Hard Accelerator Pedal?
Ever since I bought my truck I've known it to have a much harder accelerator pedal than I'm used to. I had heard that it was normal before but a couple people who are pretty knowledgeable on auto mechanics have said to me that it's not right, one even went as far as to say that it seems like someone might have modified it to be harder to press. Can anyone confirm for me if this is true and if it is, what can I do to correct the problem? I'm guessing throttle springs?
My current set up is a 350cid with an Edelbrock 4 barrel, sitting lifted on the intake.
My Wheels:
1984 Chevrolet K/10 Scottsdale 350cid *SOLD*
1989 Cadillac Fleetwood Brougham d'Elegance 307cid
2015 Chevrolet Silverado 1500 LT Texas Edition 5.3L 4x4
SourTooth307 is offline   Reply With Quote
Old 11-07-2014, 03:07 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Hard Accelerator Pedal?
My '87 is perfect; exactly the right amount of effort and comparable with other production vehicles.
My guess on your situation is that there is something wrong with the cable; either bent or damaged (wire coming undone inside the sheath) resulting in increased friction inside the cable.
I wouldn't play with return springs at the carb, if that's what you are asking. Too light (in an effort to reduce the pedal force) and the throttle might not return to idle; heavier springs will just make the pedal force worse.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-07-2014, 03:08 PM   #3
SourTooth307
K
So, new cable?
My Wheels:
Old 11-07-2014, 03:30 PM   #4
walkerb
walkerb's Avatar
I swapped out springs and it made mine better
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 11-07-2014, 09:53 PM   #5
v30crewcab
v30crewcab's Avatar
usually its the cable. they get a groove worn in them and get sticky.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-07-2014, 10:05 PM   #6
imjeff
imjeff's Avatar
Just unhook the cable and see if it moves freely. If not, lube or relace it. If it moves freely I would change springs.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 11-07-2014, 10:20 PM   #7
NorCalAnthony
My '89 K5 had a really hard pedal when I first bought it. It was so bad that my calf and ankle ached the next day after driving it home from 2 hours away...
The PO had thrown in a new throttle cable with a handful of other misc parts so I figured what the heck and swapped it out. That simple project made a night and day difference and now it's as soft as my '13 Cruze.
NorCalAnthony is offline   Reply With Quote
Old 11-08-2014, 02:00 AM   #8
SourTooth307
Good stuff man. Definitely had the sore calf and knee too. Cables gotta go.....
My Wheels:
Old 11-08-2014, 08:52 AM   #9
cadillac_al
I would unhook the springs first to see how easy it moves. It sounds like it has too stiff a spring on it.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 11-08-2014, 09:17 AM   #10
Valleycreek
This is a good start. I had the same problem, was fine when unhooked. turns out the loop in the spring would ride along another piece of the carb., causing the resistance. I moved it to a different hole and problem solved. Hope it is that easy with you. Good luck.
Valleycreek is offline   Reply With Quote
Old 11-08-2014, 05:08 PM   #11
SourTooth307
Good stuff, I'll have to check that out, I had a feeling that's where the problem might be. I gotta ask about the name Al, I'm a big Cadillac fanatic myself.....
My Wheels:
Old 11-08-2014, 05:54 PM   #12
dfrank
dfrank's Avatar
I like caddilac's myself as well. As a matter of fact i demo derbyed both of mine lol. 88 caddy fleetwood and a 98 caddilac deville. Sorry for the thread jack.
dfrank is offline   Reply With Quote
Old 11-09-2014, 08:44 PM   #13
cadillac_al
Yeah I have always liked Caddys since high school and have had a few over the years. This is my name on the Cadillac forum and a few others too. It's just simpler for me to have the one screen name. I have been driving my black 78 Seville for 18 years now and my 77 Fleetwood for 3 years. I have a 70 deville convertible and 78 coupe on the back burner. Country living has its advantages when it comes to parking a fleet lol.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
