Adding reverse lights
My 63 did not come with reverse lights. I would like to add them. Where does the reverse switch get mounted?
Re: Adding reverse lights
On a four speed it's mounted on the floor and a tab screwed to the shifter pushes a switch when put in reverse. On a three speed its mounted up under the dash in some manor, don't really know how. An automatic is probably under the dash as well.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Look in the link below marked 1963 literature. Scroll down to album marked accessory installation. You'll find the original instructions and wiring schematic.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
3 spd manual switch should be mounted to the top of the column with 2 small screws. 3Spd Auto is also on top of the column-same type of mounting I believe
I added aftermarket back p lights to my 65 Suburban, and mounted a toggle type switch under the dash. I have a TH350 trans but the wiring isn't hooked up. With the switch, I can turn on the lights separately to light up behind my truck.
Exactly what I have on my mind now. I will be installing my new weber 2bbl with electric choke. I want to mount the toggle where the choke cable comes through the dash. I bought a set of lights from Pep Girls to mount under my bumper. I would still like to do a custom mount IN the bumper.
