Matching Master Cylinder?
I need to get a new booster and master cylinder, but I'm going to be changing to discs up front in about a year. What will happen if I put the disc/drum mater cylinder on and run it with the drums up front for a while?
1968 Chevy C10 Longbed Fleetside |
You will be without a residual pressure valve. In other words your front brakes would take longer to engage and be very hard to accuratly control. Master cylinders are only $30 or so. Not worth wrecking your truck to save $30. The other option is to buy the drum/drum master, and when you upgrade to disc remove the residual pressure valve. After that the only difference is the size of the reservoir.
Good Luck CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
