Old 11-08-2014, 11:35 PM   #1
Paul83
Paul83's Avatar
Water temperature Gauge
I am having a problem with my factory temperature gauge. It is staying on the cold side and will not move. I have tried the grounding it out method and it did not move so I tried an extra temp gauge I had and it did the same thing. (needle did not move) I can't think that both gauges are broken and I have put on 2 separate temperature sending units nothing. I also tested the ohms on the ceramic piece behind both of the gauges and they are both reading 84 ohms. I have installed electric fans recently. I don't think the engine temp is staying below 100 degrees. Is there a wiring issue somewhere. Maybe I don't have it grounded good enough what do you think? All the other gauges work except my gas gauge. I am not sure if they are related or not. Any thoughts or input is helpful. Thank you.
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that!
I like long walks on the beach, dinner by candle light, and poking dead things with a stick.
Paul83 is offline   Reply With Quote
Old 11-09-2014, 12:39 AM   #2
greg64
greg64's Avatar
Re: Water temperature Gauge
Paul, sounds to me like either the wire from the gauge to the sender is broken somewhere, or the gauge isn't receiving 12V power. The sender wire is dark green, to my memory. It goes thru the firewall connector, and I think that's the only break in it. Do you have the instrument cluster apart?
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 11-09-2014, 01:01 AM   #3
Paul83
Paul83's Avatar
It is not completely apart. I just have the front covers off to take out the temp gauge.
Old 11-09-2014, 10:29 AM   #4
greg64
greg64's Avatar
Paul, if you have a multimeter, you can put it on ohms and probe between the sensor wire and ground. It'll read between about 100 ohms to a few thousand, depending on the temperature. I'm thinking you could back probe the wire where it goes thru the firewall, and then you'll know if the engine side is the problem or the dash side. You can also test right at the sensor.
Greg
Old 11-09-2014, 08:38 PM   #5
chengny
chengny's Avatar
Check as below:
Standard GM temp/resistance values for air/coolant sensors:
Check that the sensing leg (dark green lead) is intact. Pull connector from sender and ground to engine block. Then check the dash end for continuity to the frame. A broken sensing lead will keep the gauge pegged at the low end.
chengny is offline   Reply With Quote
Old 11-10-2014, 12:08 AM   #6
Paul83
Paul83's Avatar
Thank you chengny and greg. I found the break in the wire. I must have pinched part of the wire when I installed the transmission or something.
