Cab mount bolts too big?
I ordered a cab mount kit for my truck and the rear bolts are too big to fit in the threaded nut inside the cab. Anybody else have this problem? And what's a way to fix it?
Re: Cab mount bolts too big?
Someone will chime in no doubt with the exact size and length needed. I ordered my kit from GMC Pauls or Classic Heartbeat (not sure which one now). I am sure you can find the correct bolts when you have the size from Tractor Supply or even Lowes.
![]() Join Date: Mar 2000
1/2 ton 2wd Rear cab mount bolts, 7/16-14 x 6", hex head bolt
3/4 ton, 1ton 2wd & ALL 4X4 trucks Rear bolt 7/16"-14 X 8.5" Paul Jr. @ GMCPauls |
Mine were rectangular and loose inside a cage sort of thing. I just ground down the sides of a larger bolt and slipped it in the cage. Mine were all boogered up anyway.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Thanks guys. Looks like another trip to Lowe's. Just wish the kit was already made right!
