11-09-2014, 04:52 AM | #1 |
Old member
Question
I'm fixing to install 6 way electric seats /heated in my 71 truck.
My question: I have the power cable run to the amp under my seat now. I was wondering if I could tie into this cable at the power block by the speakers and run the seats with no problems with the speakers. I need a hot wire for the seat and since it's already back there I thought why not. What do you think guy's Good/Bad idea?
11-14-2014, 12:01 AM | #2 |
Re: Question
I don't see why this would be terrible, but I suppose it could lead to having feedback or noise in your stereo that you wouldn't want. I ultimately opted to just run new wires back for mine.
11-15-2014, 12:14 AM | #3 |
Old member
Re: Question
After think about it more I think I will have to run new wiring. My plan is to have them shut off when the key switch is turned off so that being said I will have to put it on a switched wire. I also plan to run the ground through the seat belt buckle so if the truck is running and you unbuckle the seat belt it will shut off to.
11-19-2014, 09:20 AM | #4 |
Old member
Re: Question
Drivers side is in. I ran a switched hot and had to rethink the ground. It didn't work through the seat belt. The switch is for a buzzer so when it was buckled it was off when you unbuckled it came on. LOL... So I just have the normal ground right now.
01-10-2015, 11:03 PM | #5 |
Loves all GMC trucks
Re: Question
Andy,
After reading is I'm glad you decided to run a new wire separate for the seats. I am fairly certain you would hear the seat motor in the speakers when you operated the adjusters. It's like having you home computer plugged into the same plug as your paper shredder. If your listening to music, it shrieks the shredder sound through the speakers. Good luck on the other side.
Mike If your helping someone and expecting something in return... your doing business not kindness! |
02-18-2015, 03:31 AM | #6 | |
Old member
Re: Question
03-01-2015, 04:03 AM | #7 |
Old member
Re: Question
I ran a hot fused wire to the back of the cab and mounted a 6 way fuse panel on the side of my sub box.
I then ran the electric seat wire from there to each seat. Each seat has it's own wiring harnes with relay's. The grounds both run through the seat belt buckles so if you un buckle your seat belt the heaters will turn off. I've had it hooked up for a month so far and no problems at all.
03-22-2015, 02:31 PM | #8 |
Re: Question
What seats are you using? You've always had a nice truck.
03-24-2015, 07:33 AM | #9 |
Old member
Re: Question
1999 Tahoe seats. Thanks!
