Should this turn or move ?
I can grab these and turn them in circles should it ??? The last i cant turn just wiggle around until bearing is in .
Soon to have 68 SWB 350 with Turbo350 |
#2
#3
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
With the column disconnected from the streeing shaft and transmission shifter rod the outer tube will spin 360deg.The inside shaft will spin 360deg. as well.
I just had my steering column apart while I replaced the turnsignal cams and wiring.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
