Old 11-09-2014, 12:35 PM   #1
NGN
NGN's Avatar
1967 327 engine 4 barl 400 trans ?
Is a 1967 327 engine 4 barl carb 400 trans the same from both a car and truck ? If so, are there any other parts I need to grab from the car.
Thanks Nick
NGN is offline   Reply With Quote
Old 11-09-2014, 01:27 PM   #2
Coley
Coley's Avatar
Re: 1967 327 engine 4 barl 400 trans ?
No, not the same.
The car engines typically were higher horsepower than the trucks which were typically designed for a lower rpm torque curve.
To my recollection those (car) 327 engines came in several hp levels...250hp (base) 275hp and 300 hp. The higher hp jobs were typically for the Corvettes or the performance chevys.
Regardless, those 327's are great little engines....you should definitely grab it if its a good price and in good shape.
My two bits.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 11-09-2014, 02:40 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
If you are talking about being physically the same, yes they are. It would bolt into a truck with no problems using the truck mounts. I would get any related parts like the shift linkage, throttle linkage, and that type of stuff. If you don't need it no problem, but if you do and didn't keep it you would be kicking yourself....
LockDoc
Leon
