Old 11-09-2014, 05:26 PM   #1
Leroy-B1
auto crossmember help
so I have a 60 apache and I am using the original frame...I did a front stub and rear end swap from a 85 Silverado to get 5 lug and disc brakes....so now I am at the point of installing my motor and tranny...I was wondering what you guys used for the transmission cross member in the x frame and if anyone had pics .....also looking for some help on where the crossmember needs to be...going with 327 and a 700r4 using the 85 engine mounts on the frame...any help would be great
Leroy-B1 is offline   Reply With Quote
Old 11-09-2014, 05:30 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: auto crossmember help
I saw a real simple one made with angle stock.
I'll see if I can find it.
66 C20 Service Truck:
Old 11-10-2014, 01:01 AM   #3
Captainfab
60-66 Nut
There is a hole pattern of 3 holes on each side of the X-member. This is where the factory auto trans crossmember bolted in.
Old 11-10-2014, 06:35 AM   #4
Leroy-B1
Captain fab I didn't see any holes or remember seeing those I'll look again...do you have a pic....thanks guys
Old 11-10-2014, 07:03 AM   #5
LostMy65
LostMy65's Avatar
I wonder if Captain is thinking of the 63+ frames, I don't remember seeing the bolt holes on my 62 frame either.
Old 11-10-2014, 07:05 AM   #6
LostMy65
LostMy65's Avatar
Here's one thread;
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
Old 11-10-2014, 07:07 AM   #7
LostMy65
LostMy65's Avatar
Here's another thread;
http://67-72chevytrucks.com/vboard/s...d.php?t=506673
Old 11-10-2014, 07:13 AM   #8
LostMy65
LostMy65's Avatar
I still haven't found the thread where the guy made his own out of angle stock.
But here's even another thread;
http://67-72chevytrucks.com/vboard/s...d.php?t=452568
Old 11-10-2014, 07:21 AM   #9
LostMy65
LostMy65's Avatar
As far as locating where to mount it ....
My plan when I go to do mine is to secure the front of the engine block so when I remove the manual tranny and bellhousing, the engine stays located and tilted in the same location.
Then I was going to bolt up my auto tranny to the engine. Then I'll know where the mounting location of the tranny crossmember needs to be.
Old 11-10-2014, 07:31 AM   #10
LostMy65
LostMy65's Avatar
I found the thread with the homemade one made out of angle stock;
http://67-72chevytrucks.com/vboard/s...31#post4216931
Old 11-10-2014, 08:41 AM   #11
Leroy-B1
Thanks for help....looks like I'll be making one ....may use a factory one from something else and modify it
Old 11-11-2014, 12:46 AM   #12
Captainfab
60-66 Nut
Nope, it is on the '60-'62 frames. It is also mentioned in post #15 or the thread you linked below. I'll have to see if I can get a pic and post it.
