Old 11-09-2014, 08:53 PM   #1
90four5spd
GMC leaf spring rear flip kit shorter shock part number
Hey guys. Doing a home made flip kit on my gmc leaf spring rear. I think the frame is a 71ish? Not sure, but flipping the axle above the springs. Both shock mounts are pointing towards the front of the truck. Does anyone know the part number for the shorter shock i would use after flipping the rear end? Thanks
90four5spd is offline   Reply With Quote
Old 11-10-2014, 01:35 PM   #2
sKnNyPpY
sKnNyPpY's Avatar
Re: GMC leaf spring rear flip kit shorter shock part number
You can use the front size shock on the rear after a flip. I used that on my LWB with Monroe Sensa-Trac with no c-notch. Make sure to trim down or install shorter bump stops and relocate your shock mounts to the other hole for a more upright shock position.
http://67-72chevytrucks.com/vboard/s...d.php?t=577529
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
