Lower control arms
Can the 73-87 upper and lower control arms be bolted on the 63-66 cross member or do you have to change the whole cross member out?? Thanks Jeff
Never Ending Projects
Re: Lower control arms
Short answer is yes.
If you look in the FAQ, post #4, it has all the suspension questions links that will tell you everything you need to know. http://www.67-72chevytrucks.com/vboa...d.php?t=646002
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
I read a whole bunch in the facts but I guess I didn't comprehend that exact answer. Thanks.
60-66 Nut
![]() ![]() Join Date: Mar 2007
It is a good idea to upgrade to the larger '73-'87 lower control arm U-bolts while you're at it. The stock '63-'66 U-bolts have been known to break. I have had 2 break and been lucky that it happened while driving slow.
It's for a friend and I've already told him about the Ubolts, I just wanted to make sure I didn't steer him wrong. I tried to talk him into doing the whole thing but he just wants to do control arms. Thanks
