Old 11-09-2014, 09:33 PM   #1
badchevy
odd things on my 87
Wondering if any of you (especially ones who own 87s) have the following odd/different things on their trucks. Well this is according to me.
First thing is the driver's door lock. The switch does not operate up/down. This one operates front/back.
Second is it came from factory with no front sway arm. This is according to the original and second owner (father initially purchased truck). I'm the 3rd owner.
Third is it has a factory lock for the spare tire. It's a locking cover that fits after the eyelet bolt. Sorry, don't have any pics at the moment but can take if needed.
Thanks for the feedback/help.
badchevy is offline   Reply With Quote
Old 11-09-2014, 10:01 PM   #2
badchevy
Re: odd things on my 87
Here is a pic of the door lock and spare tire lock.
Old 11-09-2014, 10:03 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
My 87 the door lock switch is up down. Yours needs to be rotated, easy fix. Cant help with the rest..
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 11-09-2014, 10:07 PM   #4
badchevy
Can't rotate it. The hole is rectangled. Looks like this is how it came from factory.
Old 11-10-2014, 03:48 AM   #5
Greenlee
Greenlee's Avatar
Is it a Mexican truck? There are some odd features from across the border and I noticed you are in a border town.
Greenlee is offline   Reply With Quote
Old 11-10-2014, 03:57 AM   #6
chengny
chengny's Avatar
No, somebody turned a pair of non-power panels into power panels and in the process they cut the lock opening 90 degrees off.
The bezels are rectangular in shape and can only fit in one way. The factory panel cutout is slightly longer in the horizontal plane (and so is the bezel - when LOCK is at the top or bottom).
Leave it like that anyway - gives the truck character. Street cred.
chengny is offline   Reply With Quote
Old 11-10-2014, 08:21 AM   #7
Keith Seymore
Keith Seymore's Avatar
a) Somebody screwed up on the door lock. Should be up/down.
b) The spare tire lock is a GM accessory.
c) Front sway bar is optional. The person that ordered the truck did not choose RPO F59.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-10-2014, 09:40 AM   #8
Just call me Sean
Just call me Sean's Avatar
That is not a normal lock button. If it was installed as it is supposed to be then "lock" would be upside down. Looks like a normal button would fit there.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-10-2014, 11:29 AM   #9
badchevy
The truck is not a Mexican truck but does belong to a Mexican. lol
I did forget to say that the door lock switch is not square, it's rectangular. If I was to install it the "right" way (up/down), the switch would not even with the window switches as Sean's pictures show. I don't have a problem with the switch. Only thing I'm worried about is what I'm going to do when the switch ever decides to go out. I don't think I'll be able to find another that's the same.
Old 11-10-2014, 11:54 AM   #10
chengny
chengny's Avatar
That switch bezel thing is bizarre. I didn't notice at first but, it is normal in every way except for the location of the "LOCK" marking.
Mr. badchevy's is on the righthand side border rather than on the bottom (like every other bezel I have seen):
And even if were indexed so that LOCK was on the bottom rail, it still wouldn't be correct - the lettering would be upside down. The way it is printed, no matter which way you indexed it, you would still have to push up on the toggle switch to move it towards the LOCK position.
Ha! That switch bezel might be worth big money - you know, like a rare misprinted stamp.
Old 11-10-2014, 12:58 PM   #11
silvereagle07
silvereagle07's Avatar
The door lock switch is likely from an 80's Pontiac, Buick or Chevy car. They had the lock word inscribed at the top of the switch.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 11-10-2014, 01:58 PM   #12
Keith Seymore
Even if it was factory (...it's not...) it wouldn't be rare.
We have a saying here: "At Chevy, you don't make a mistake. You make a million of 'em".
K
1979-1986
1986 - 2019
Old 11-10-2014, 03:23 PM   #13
chengny
chengny's Avatar
Sorry, that was my idea of a joke.
Old 11-10-2014, 04:47 PM   #14
Keith Seymore
K
No problem.
This was my idea of a joke, too.
K
1979-1986
1986 - 2019
Old 11-10-2014, 05:36 PM   #15
badchevy
I took the door panel off a while back and all looked normal. I have to take the door panel off again to replace the arm rest. I'll check for any markings on the switch and panel.
Old 11-10-2014, 08:36 PM   #16
Just call me Sean
Somebody just put in the wrong switch. While I can't think of which particular vehicles came with that switch I am familiar with the lock type it would be used for.
Old 11-10-2014, 10:00 PM   #17
badchevy
Only thing is the window switch would be a little closer to carpet trim piece/door handle. If the wrong switch was installed, then the panel had to be cut differently for placement of both switches. You can see this if you compare the placement of the switches in the pic I posted and you posted.
Old 11-10-2014, 10:21 PM   #18
Just call me Sean
They're both the same size, or at least look like the hole would be the same size. I can measure one if you want. Or I can measure the hole.
Old 11-10-2014, 10:39 PM   #19
badchevy
No need. I just went and compared my '82 and '87. The window switch is a tad bit farther forward than my 82 but nothing too drastic.
Old 11-10-2014, 11:01 PM   #20
Just call me Sean
That doesn't matter, it doesn't affect the lock switch. Putting in the correct one would make it look, well, correct.
Old 11-11-2014, 11:47 AM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
Swapped parts to fit the 78 Jimmy
89 pass side (Burb PW/PL)
87 drivers (Burb MW/PL)
yup mid 80s I'd say a Grand Prix?on the pull handle ledge,makes it Fwd/Back
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
