Old 11-10-2014, 10:12 AM   #1
77chevyinline6
77chevyinline6's Avatar
Question Big swap here. whats different?
okay guys need some advice here! the old straight 6 dropped a valve the other night, and the trusty saginaw 3 speed decided it was time to go too. at my local pull a part you can get any v8 with accesories for 175$ any automatic with converter for 75$. whats different transmission wise? crossmember? driveshaft?
thanks guys.
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 11-10-2014, 05:24 PM   #2
NJ C10 Guy
Re: Big swap here. whats different?
i just finished collecting parts for my swap, from a saginaw 4 speed to a 700r4. here is what i needed:
torque converter and bolts
lockup converter
crossmember
flexplate and bolts
trans cooler lines (youll need a new radiator or trans cooler if you dont have one already)
starter
shift linkage
shifter
tv cable
bellhousing bolts
driveshaft will need to be shortened or lengthened
thats all i can think of now, but i think i covered it for the most part.
NJ C10 Guy is offline   Reply With Quote
Old 11-11-2014, 12:07 AM   #3
77chevyinline6
thanks! my radiator is aftermarket and has trans line hookups, and why is the starter different? mine bolts onto my engine. ive seen people say its different a few other times, and could i just get a driveshaft out of another c10 that is auto?
Old 11-11-2014, 10:54 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
If included and have time
I'd get the engine mounts and bolts,(even if you replace them)even the wire harness right to the plug.(they prob move spots)
maybe cruise control?
I'd leave the manifolds on till your home.
not sure if the gauges to sensors are different....
but I know the gas gauge goes faster! lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-11-2014, 02:00 PM   #5
NJ C10 Guy
ill be honest i dont know the ins and outs of it, all i know is that it was recommended to me to do it. this will be my first swap and i spent a decent amount of time doing research so that i wont have to stop in the middle and get another part. as far as the driveshaft goes...if you find one out of a truck that carries the same drivetrain that you're going for i dont see what the issue would be, but i can't confirm that to be true.
Old 11-12-2014, 10:28 AM   #6
walkerb
walkerb's Avatar
Your Saginaw gave up? What happened? 4 bolt or 5?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 11-12-2014, 11:00 AM   #7
77chevyinline6
it got to when i would push and hold the clutch in idling it would make this grinding noise like the flywheel rubbing, but i laid under it and had a friend hold it in and it was coming from the trans,
Old 11-12-2014, 11:31 AM   #8
jetmech85
May be the throw-out bearing. Check it when you remove the trans, if that's the problem then you have a good transmission to sell.
jetmech85 is offline   Reply With Quote
Old 11-12-2014, 11:33 AM   #9
brakenit
Active Member
It's more likely that it's the throw out bearing if it's only making noise when the clutch pedal is depressed.
brakenit is offline   Reply With Quote
Old 11-12-2014, 12:23 PM   #10
77chevyinline6
i took out the throwout bearing and it spun smooth and freely, i dont understand it.
Old 11-12-2014, 01:14 PM   #11
jetmech85
Transmission, as you probably know, should not turn when the clutch is depressed. I had a bad pilot bearing that ate up the trans input shaft or possibly excess wear on the crank thrust bearing letting the crank/flywheel move forward into something. That would be a lot of wear! Might try to pry the flywheel forward and aft to check for end play.
Old 11-13-2014, 08:06 AM   #12
walkerb
walkerb's Avatar
Hard to kill a Saginaw. If I was closer Id buy it if it was a 5 bolt truck trans.
