Old 11-10-2014, 11:51 AM   #1
papaws66
offset rims on 66 c10 lwb
how much offset will fit on a 66 c10 without any mods? i'm looking at some 15x8's with -13 offset.
also, how wide of a tire can i put on that without any mods? don't want to change anything but the rims!
here's the link: http://tirecrazy.com/wheels/pacer/34...FY9aMgod7T8AGQ
let me know!
thanks
papaws66 is offline   Reply With Quote
Old 11-10-2014, 11:52 AM   #2
papaws66
Re: offset rims on 66 c10 lwb
also, is that the right lug pattern?
Old 11-10-2014, 12:26 PM   #3
4shongo
If you have 6 lugs; 6x5.5 is correct!
4shongo is offline   Reply With Quote
Old 11-10-2014, 02:00 PM   #4
papaws66
yep, they're 6 lugs! i didn't want to take the hubcap off to measure.. too hard to get back on! thanks
Old 11-10-2014, 07:05 PM   #5
LVPhotos
LVPhotos's Avatar
I have 18x8.5 at 4.5" backspace and 18x9.5 rear at 4.5". 295/45/18
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-10-2014, 09:09 PM   #6
gimmy 64
15x8 4 1/2 back space. rear tires i had 275-60-15. you have about a finger space between tire and bedside. this on a lowered fleetside
gimmy 64 is offline   Reply With Quote
Old 11-10-2014, 10:47 PM   #7
papaws66
so... i need positive backspacing for it to work good? honestly i have looked to see how much space i have with the originals.. thanks for the replies!
Old 11-10-2014, 10:57 PM   #8
hopped up
hopped up's Avatar
Ban you've got that wheel/tire combo down! I'm a steelie guy but those are awesome!
hopped up is offline   Reply With Quote
Old 11-10-2014, 11:09 PM   #9
papaws66
this is probably a dumb question, but the only way to find out is to ask... what's the difference in offset and backspacing?? thoroughly confused.. never had to buy any before! (also... google is confusing )
Old 11-10-2014, 11:32 PM   #10
papaws66
never mind.. i found a diagram that explained it good. feel pretty dumb now, cause if you think about it hard enough it makes good sense!
Old 11-11-2014, 12:09 AM   #11
papaws66
i'm thinking maybe these rims with some 275/65r15's on back
http://www.streetsideauto.com/p/keys...els-297-5860p/
maybe a little smaller in the front
what do ya'll think?
15x8 tire size, offset rims
