1960-62 C-30,40,50,60 truck cabs
Well guys im feeling pretty down these last 3 weeks
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
Re: 1960-62 C-30,40,50,60 truck cabs
the major part is that you have to install what ever hump that you need as the floor is flat in the higher nbr'd cabs. 30 series is the same as what you have.
ron |
Who did he have for insurance? Also do you have receipts of the parts on the truck, because you may be able to get a lot more for it if you kept the paperwork.
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
#4 | ||
My insurance company and the other are not working with me and the wife because we are being represented by a injury attorney.. I did send an email with reciepts totalling over $13,000.00 and also the NADA value report to the other (liable) insurance co. Just waiting for a responce..
#5 | |
I understand, I did the same with my '67. I hope everything works out well for you.
I get sick in the stomach looking at it so I covered up the truck with a tarp.. I thought I share a pic....
![]() Join Date: Nov 2007
OMG! I am so sorry that happened to your truck.
1963 Chevrolet C-10 "Ginger" ![]() 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
![]() Join Date: May 2007
That's a real shame.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
1961 crewcab
yes with what is left of your truck. you will be able to make the c 60 cab work. the major difference as padresag stated is the high hump, the c 60 has a flat pan, but the rear half is bolted in, so all you need to do is cut the front half off your truck, and bolt in the rear. another neat thing is that both pieces of the floor pan on the 60 series bolt in, so when you go to install your high hump front half, you can just drill some holes and bolt it in.
a LCF (snub nose) cab is not a direct bolt in replacement, the front floors are different. there is a extra floor brace on a 6o series that runs under the front half of the floor hump, that will need to be removed.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
My suggestion is to start looking for trucks in "similar" condition, similar age etc.
I say this because if you have proof of its worth, then you can hold out for more. SO you said, $13k in receipts, plus the truck? $3k so your in for about $16k or so, not including labor. If you can find a comparable truck on ebay or CL or?? get pictures and detailed descriptions so you have one or two that come close. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#11 | ||
Thanx for the words..
Yeah I know.. Quote:
one thing you need to know/remember is that YOU are the claimant not the insureee (not spelled right im sure) its is your truck NOT theirs don't let them take it ...retain salvage and do NOT give them the pink slip/ownership certificate
#13 |
makes me sick to see the picture....
Glad you're OK, sorry about the truck.... |
#14 |
Oh man doobiebro!? I hope you're ok man. Let me know if you need any thing. You'll get it going again. I think I've seen a sixty laying around here somewhere, I'll let you know.
#15 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
That just makes me sick to see.....I hope you're alright. You have worked on this truck for so long and have driven it for a relatively short 2 years. I do hope you are justly compensated.
#16 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Extra cab support on a C60.
Factory hole beside drivers seat rear bracket for fuel gauge and reverse lights if I remember incorrectly. The fender support brackets 8.155 off the incline reinforcement have to be changed to the light duty versions. ![]() Well it was held in with 14 bolts and then spotwelded.....Man does that leave alot of holes in the floor. Notice the extra spot welded bracket behind the clutch rod, this is a support bracket for the vacuum lines from the remote brake booster attached to the frame beneath the cab. There's also the vacuum manifold directly above it just below the master cylinder. There is also a pipe coming out of the rear drivers side cab mount for the Brake Booster Vent.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 11-12-2014 at 07:04 PM. |
#17 |
1961 crewcab
I will have to get a couple pics, I think the column bracket is spot welded in a different spot on the firewall, low instead of high. (this is on my 60)
63 will probably be a little different yet because of the non hydraulic clutch.... although it is interesting to note that my 66 60 series retained the hydraulic clutch, and still used the outer cab mount bolts in the front like the 60-62 c/10's all this should be easy stuff to rectify, however it is good to get it all listed in one spot,
#18 | |||
![]() Quote:
![]() Quote:
![]() Thank you Captain! Enjoyed driving that truck and always like seeing thumbs up from a lot of people. Compensation I feel is fair and I think it will cover all the repairs if I do a lot of it myself
#19 | ||
#20 |
Aw man, sorry to hear Doobie. Too many careless drivers around here. Thank God you and your family are physically okay. Let's get you back on the road brotha.
![]() '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
#21 |
NOOOO!!!!!! I showed my dad a photo of your truck you posted on my build thread for inspiration. Don't give up on it. Build her back to life.
Stovebolt-It is painted |
#22 |
can we get more pictures of your cab ?? was it a rust free cab ?? did it only wrinkle or warp much past the center of the cab ??? you see where I am going with this don't you ???
#23 |
Sorry to hear about your truck I was t boned in my 66 a couple years back I ended up finding another cab but it just didn't feel like the same truck anymore I ended up selling it witch I still regret hopefully you get it fixed up
#24 | |
thanx buddy, will fix her up again!! To much sentimental value with my girls..
#25 |
Just the cab alone I spent $500.00 on just the 2 doors (rust free) and another $500.00 for replacement sheet medal - upper and lower rocker panels, 1 cab support, patch pieces on the floor and lower sections on the front fenders many years ago.. the top cab roof is wrinkled and the cab is tilted on one side but dont see anything on the frame..i have lots more pics but from the accident scene and dont wanna show all 5 kids who were stuffed in a 2002 nissan sentra R (2 poor young girls were hurt and treated) here is a few pics..
