Old 11-11-2014, 08:13 AM   #1
Mr Handy
Mr Handy's Avatar
WTB Pullies & Intake Vac fitting
Hi All, I'm trying to finish up my engine so I can get it in the truck and I need a few pieces.
1. A Pulley set for short water pump... single or double groove will work... If you have a pair of both I may take both sets. As long as they are straight I'm happy to clean and paint.
2. I also need the T fitting to connect trans VAC line and booster line... 3/8 NPT- 1/4" nipple-3/8 nipple... I think.
3. While I'm at it I might as well ask for a set of 4 Painted dog dish hubcaps for a c10... My truck is a base model, not many options and I would like to put back the painted caps. nothing fancy, just reasonably straightenable and not rusted out.
Thanks in advance,
Andy
Mr Handy is offline   Reply With Quote
Old 11-11-2014, 09:11 AM   #2
WETOWM
Re: WTB Pullies & Intake Vac fitting
I may have the vac tee also the pully set do you have p/s ?
WETOWM is offline   Reply With Quote
Old 11-11-2014, 09:40 AM   #3
Mr Handy
Mr Handy's Avatar
No I just have the alternator currently and plan to add ac at some point.
Old 11-11-2014, 10:51 AM   #4
michael bustamante
michael bustamante's Avatar
I have a few different style vacuum tees. I can send you a pic if you like
1967custom
michael bustamante is offline   Reply With Quote
Old 11-11-2014, 10:58 AM   #5
Mr Handy
Mr Handy's Avatar
Pics would be awesome!
Old 11-11-2014, 04:19 PM   #6
michael bustamante
Pics sent to you
1967custom
Old 11-11-2014, 07:49 PM   #7
Mr Handy
Mr Handy's Avatar
Originally Posted by michael bustamante View Post
Pics sent to you
Got the pics, I'm trying to find one with the barbs on opposite sides. seems like the vac line for the trans needs to come off one side and the line for the booster off the other... I'm thinking I will have to pull the one off the old motor and clean it up.
thanks for taking the time to take and send the pics.
Old 11-11-2014, 11:01 PM   #8
michael bustamante
No problem bud. I bet someone on here has a true "T" tee
1967custom
Old 11-11-2014, 11:16 PM   #9
hardwaycooke
hardwaycooke's Avatar
Thanks in advance,
Andy
I have original T fitting still on my old manifold I removed 3 months ago.
Also I recently added PS so I wet thru a lot of pulleys. I have crank dbl and single add-on for it.
I have another crank cast dbl.
I have water pump dbl and single for Short pump.
Also have couple alt pulleys.
Some are powdercoated dull chrome. I can send better pics of everything tomorrow if you are interested. Thanks
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 11-11-2014, 11:40 PM   #10
Mr Handy
Mr Handy's Avatar
I'm definitely interested in the T fitting and either a set of water pump and crank Pulleys single or double... or maybe both. Hoping for just painted pulleys as I want to stick with a fairly stock look and have the black paint for them.
Old 11-11-2014, 11:45 PM   #11
hardwaycooke
will take pics tomorrow evening and send. thx
71 LWB
B&M Pro Shifter
Truck Name- Spike
Old 11-12-2014, 01:51 AM   #12
FirstOwner69
FirstOwner69's Avatar
Is this the vacuum fitting you are looking for?
https://www.paragoncorvette.com/p-35...m-fitting.aspx
FirstOwner69 is offline   Reply With Quote
Old 11-12-2014, 07:27 AM   #13
Mr Handy
Mr Handy's Avatar
Yup that's the one. I have one on my current engine, but was planning to keep that engine complete when I pull it in hopes it will be easier to sell as a running engine. and in hopes I can have my new one 100% ready to drop in.
I cant see paying $30 with shipping for a fitting I can make with spare parts and a torch... I thought I would see if anyone has a bunch laying around because I know it came on more than vets.
Old 11-12-2014, 09:59 PM   #14
hardwaycooke
Heres what I have. The vacuum port is a single. Sorry. See pic. I have lots of combinations of pulleys and some brackets. Some are PC but should be able to prep and paint. Just let me know. Thanks
71 LWB
B&M Pro Shifter
Truck Name- Spike
Old 11-12-2014, 10:01 PM   #15
hardwaycooke
Heres some additional pics.
71 LWB
B&M Pro Shifter
Truck Name- Spike
