Old 11-11-2014, 11:44 AM   #1
jtwells
Question What size hole are the frame rivets in?
Hello, I need to know what size hole the frame rivets are. I need to drill some new holes but do not have any drill bits that large nor do I have any measuring devices I trust to be accurate enough to make a snug fit. Thank you
jtwells is offline   Reply With Quote
Old 11-11-2014, 12:53 PM   #2
that_ry_guy
Re: What size hole are the frame rivets in?
I found most of them to be somewhere between 3/8 and 7/16. The 3/8 bolts seemed to fit quite loosely so I ended up boring out the holes with a 7/16 bit for a tight fit.
that_ry_guy is offline   Reply With Quote
Old 11-12-2014, 12:55 AM   #3
kwmech
The holes are 10mm or you can use a letter X drill bit. I usually drill to 7/16 and use a fine thread grade 8 bolt and torque to70 lbs.
Old 11-12-2014, 01:10 AM   #4
'68 Newtricks
'68 Newtricks's Avatar
x3 on spending the time to drill a clean, ROUND hole for a 7/16 bolt instead of the beat up ~3/8 holes. My whole C10 frame is done this way, my Blazer is getting there
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
