08-16-2003, 09:14 PM | #1 |
need help on u-joint removal
I have a 71 4x4 front axle u-joint that is very stubborn. I have all the clips out, but cannot get the u-joint to move in any direction. Is there a trick to getting those thing out?
08-16-2003, 09:59 PM | #2 |
Robert Olson Transport
blast it with liquid wrench then the next day ya beat it out the usual way
08-16-2003, 10:05 PM | #3 |
Thanks for the tip. I have wd40 handy, will that be just as good?
08-17-2003, 08:20 AM | #4 |
Fabricator
Yes if that doesn't work take a torch or a cheap map gas torch the kind you buy at the hardware and start heating up the outer portions of the drive shaft. Get it red hot and they should come out easy. If not do the same and put it in a press. If that still doesn't work ship it to me I have a 250 ton press I'll do it for free for ya.
84 C30 Chassis 60 & 14, 454/400/NP205 Retroing 98 X-tended Cab Built with the blood and sweat from the hands of a Chevy man. |
09-03-2003, 07:31 PM | #5 | |
20' Daredevil (Ret)
09-03-2003, 09:21 PM | #6 |
Try some PB Blaster That stuff will free the locks at Ft, Knox
EXPERIMENTAL STAGES OF SANITY _____________________________ Run whatcha brung, and hope you brung enuff |
09-03-2003, 10:39 PM | #7 |
AFTER SQUASHIN MY THUMB LIKE A GRAPE WITH A 3LB SLEDGE, I BROKE DOWN & BOUGHT A U-JOINT & BALL JOINT PRESS. IT WAS LIKE $26.00 AT HARBOR FREIGHT. PUT AN IMPACT WRENCH ON IT & IT WILL MOVE ANY U-JOINT NO MATTER HOW STUCK IT IS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-03-2003, 11:45 PM | #8 |
That is a good idea John, but I ended up using a torch. I cut them babies out.
09-04-2003, 06:50 PM | #9 |
WHOO HOOO! Nothin works like the ol GAS AXE
