Old 08-16-2003, 09:28 PM   #1
brad20653
Harness
Is the harness the same on 67-72 i think my gauges was changed because the bezel on it doesnt have a choke hole but if i take bezel off theres a hole in dash for it. Will this affect lights and stuff working do i need to change the harness ?
Soon to have 68 SWB 350 with Turbo350
brad20653 is offline   Reply With Quote
Old 08-16-2003, 10:29 PM   #2
jmanz69
Careful, they attack...
jmanz69's Avatar
There is always the hole in the steel part of the dash on most trucks. Even without the manual choke. It might have a new plastic bezel though. The harnesses were different, but only for trucks with full gauges and trucks without full gauges (idiot lights). If you have a low option truck and you now have idiot lights, then you are probably running the correct harness. Look in your glovebox and see if it is listed on the option list.
jmanz69 is offline   Reply With Quote
Old 08-16-2003, 10:35 PM   #3
palallin
Every dash I've ever seen has the holes.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
