Old 11-12-2014, 12:54 AM   #1
elane352
Engine Casting #s - 350 small block
Greetings!
My 64 C-10 has several parts that are not standard.
If I need to find the engine casting numbers, am I right in thinking that the numbers are behind the head on the driver's side?
If so, I am going to have to contort my head and neck like crazy to see if I can read the numbers. There is not much room there.
Eddie
elane352 is offline   Reply With Quote
Old 11-12-2014, 01:06 AM   #2
elane352
Re: Engine Casting #s - 350 small block
I have attached some pics just in case they were needed for anyone to respond.
Old 11-12-2014, 01:17 AM   #3
VonDog
VonDog's Avatar
Try using your cell phone and take a picture. That's how I got mine.
VonDog is offline   Reply With Quote
Old 11-12-2014, 01:35 AM   #4
Captainfab
60-66 Nut
Unless the block has been decked, there is also the date code and build code stamped on the pad in front of the passenger side head.....below your alternator.
Old 11-12-2014, 01:56 AM   #5
Trap62
Trap62's Avatar
Here's a pic showing where it's located on a 305 -- should be the same for a 350.
Trap62 is offline   Reply With Quote
Old 11-13-2014, 12:52 AM   #6
elane352
Thanks for the responses. I will check things out on Thursday.
Eddie
