Old 11-12-2014, 03:40 AM   #1
bh86
monroe sensa trac 4/6 drop
i have a 82 swb I'm in the process of building. I've got a mcgaughys 4/6 drop and I wanna run the monroe sensa tracs but need to figure out which part number would be correct, if anyone knows i'd appreciate the help!
bh86 is offline   Reply With Quote
Old 11-12-2014, 03:46 AM   #2
craig113
Re: monroe sensa trac 4/6 drop
I would call them in the morning and ask support...
MONROE SHOCKS & STRUTS: Contact MonroeŽ by Phone - 1-734-384-7809
8:30 a.m. - 5:30 p.m. EST M-F
also found this in one of the forums..
Re: lowering c10 1970, same shocks?
Let me give you a little bit of advice. If you buy stock front shocks for the front and install them on the rear you now have 5" drop rear shocks. I looked in the CPP catalog and the part number for the rear 5" drop shocks is the SAME part number for the front stock shocks. I did this on my 72 and they work perfectly. Just went down to Oreillys and bought some Monroe stock front shocks for like $20 each and saved some money.
Shawn
another link
http://67-72chevytrucks.com/vboard/s...d.php?t=335035
craig113 is offline   Reply With Quote
Old 11-12-2014, 03:49 AM   #3
bh86
thanks!
Old 11-12-2014, 02:15 PM   #4
bh86
Anyone know if I can order the factory length fronts and run them in the rear? I called and they told me their weren't any in a shorter application. They said the factory length for the front according to what they have listed is 9 3/4 compressed and 14 1/4 extended. I wanted to see if anyone knew wether or not they would work in the rear and I could figure something else out up front. Thanks
Old 11-12-2014, 04:11 PM   #5
Tilt
I have 3" spindles and 1 coil cut off the stock springs and put on a set of the Monroe Sensa-Trac shocks (37049) on my 86 and they work great so far. I haven't put any on the rear yet.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 11-12-2014, 05:28 PM   #6
bh86
Thanks I think I'll give those a shot
Old 11-12-2014, 05:51 PM   #7
camshaftgsxr
camshaftgsxr's Avatar
i have sensatracs on my 84 with about 3 inches of spring drop, they will blow out very soon after install. jegs has nitro drop shocks for like $40
camshaftgsxr is offline   Reply With Quote
Old 11-12-2014, 05:58 PM   #8
midnight rambler
midnight rambler's Avatar
I put shock extenders on the rear and ran there air shocks.
midnight rambler is offline   Reply With Quote
Old 11-12-2014, 06:22 PM   #9
bh86
How do the nitro drops ride? Decent?
Old 11-12-2014, 08:23 PM   #10
bbbc10
Diggin The SquareLife
I have them they ride good to me
bbbc10 is offline   Reply With Quote
