11-12-2014, 11:44 AM | #1 |
Robert Olson Transport
74-76 front harness routing
Someone please refresh my memory is it possible on the 74 custom deluxe model that the front wiring harness goes along the bottom of the radiator support?
11-12-2014, 12:19 PM | #2 |
Re: 74-76 front harness routing
I know my 74 runs across the top of the radiator.
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
11-12-2014, 12:47 PM | #3 |
My 78 runs across the top of the radiator also. If you want to run it under you will most likey have to lengthen the wires to the passenger side headlight.
John 82 Chevy Silverado 350ci/TH350 |
11-12-2014, 01:54 PM | #4 |
And the chassis grounds are in different spots. You can run them underneath if you mimic the 81-87 style harness-but, keep in mind the low beams are wired in series, high beams are parallel.
11-12-2014, 02:36 PM | #5 |
Slots go on anything!
My '74 runs across the top as well.
1974 Jimmy- 5.3/4L80e/NP241 |
11-12-2014, 06:09 PM | #6 |
thank you for the replies.. Im putting a truck together from pieces. The cab is a 74 as is the chassis. the radiator support is out of a 78 or 79. I finally found the right wiring harnesses. Apparently the front harness is different for the 76 custom deluxe 3 speed and a 74. the headlights are wired shorter. Once I figured out that I had the right harness and all it kinda fell together. I will post some pics on my build thread
